Ignition switch
Old Sep 19, 2014 | 05:05 PM
n3hcp's Avatar
n3hcp
Ignition switch
I've recently noticed a situation with the ignition switch in our 2013 F-350. Normally, when the key is inserted, some of the systems come to life and the seat moves from the rear position to the driving position. Recently, when I put in the key, sometimes it works, sometimes it doesn't and sometimes the seat starts to move front and then goes back to the easy-out position. Flipping the key over sometimes makes a difference but it does it with both factory keys.
Clearly, this is an ignition switch problem. My question is, is it worth worrying about? I'm sure warranty will replace the switch, but will that result in the need for new keys? We have a couple additional keys that aren't cheap so if I don't have to replace them, I'd rather not!
Old Sep 19, 2014 | 05:47 PM
EO2SeaBee's Avatar
EO2SeaBee
My ex has an '08 Edge Limited that had the same symptoms. It was the memory module rather than the ignition switch. Perhaps you will also get lucky in that regard.
Old Sep 19, 2014 | 06:19 PM
Chad149's Avatar
Chad149
If they have to replace the ignition tumbler it will be keyed the same.
fordman19762003
2009 - 2014 F150
Aug 7, 2017 11:58 AM
Daddywags
Oct 19, 2011 10:38 PM
brknight
Jan 2, 2011 09:13 PM
jeff_67cougar
Aerostar
Sep 9, 2002 06:03 AM
