Tilt column swap
Old Nov 17, 2003 | 12:44 PM
66MercMan's Avatar
66MercMan
Tilt column swap
I have done a quick search and haven't came up with a yes or no answer. Can I swap a tilt column from a early 80's F-150 into a 78/79 F-250? If so what would it require?
Thanks in advance.
Old Nov 17, 2003 | 07:13 PM
fordman428's Avatar
fordman428
i am not sure it would fit right but i know they changed styles from 78 to the early 80's.
Old Nov 19, 2003 | 06:26 PM
mk's Avatar
mk
I don't think so. The steering box was moved ahead of the engine crossmember in 80 so the shaft will be longer. Not sure if you can shorten it easily at the joint in the eng compartment. The turn signal switches and tilt mechanism parts will interchange from 78-86, though.
mike
Old Nov 19, 2003 | 08:11 PM
theonlybull's Avatar
theonlybull
how about a 78-79 tilt colum??
Old Nov 20, 2003 | 08:35 AM
73Custom's Avatar
73Custom
The '78-'79 tilt column will bolt right into your '78... wire colors may vary, but that's no big deal with a diagram.
Marty
SuperDuty93
13
Jul 13, 2012 08:33 PM
FE406
Mar 20, 2008 11:56 AM
vinlin95
24
Jan 1, 2008 05:03 PM
ford-nut
Feb 25, 2005 07:35 PM
analyte
Aug 18, 2003 08:30 PM
