Sponsored by: Real Truck
ignition cylinder lock
Old Jan 12, 2012 | 05:32 PM
chuckyl's Avatar
chuckyl
Need forum expertise/advise. I own a 2006 f350 6.0 the cylinder lock has a lot of slop. This as led to the battery running down on several occasions. I priced a cylinder lock from ford 112.00 but the kicker is they want an addtional 145.00to match my current key to the new cylinder lock. Any thoughts or advice on this matter will be greatly appreciated. Thanks in advance Chuck
Old Jan 12, 2012 | 08:10 PM
dchamberlain's Avatar
dchamberlain
Check with some good locksmiths and see if they can get you a cylinder lock and/or match it to your existing key. Not many locksmiths may be able to actually get you the cylinder, but I'm pretty sure any decent locksmith should be able to re-pin it for your key. And probably for way less than Ford wants.
Your other option is to just carry two keys. One for the doors and one for the ignition.
Old Jan 12, 2012 | 08:19 PM
true blue's Avatar
true blue
Locksmith is much cheaper. I keyed mine myself because I am "frugal". You can mess it up in a hurry if you are not careful though.
Old Jan 13, 2012 | 01:51 AM
chuckyl's Avatar
chuckyl
oop's
I posted this twice. Thanks for the quick response. Does a new key come with the cylinder lock? I don't care about two keys.
Old Jan 13, 2012 | 08:04 AM
ccerniglia's Avatar
ccerniglia
$145 to code a cylinder?! Guess I need to start charging $100 more. Its really easy and you could do it yourself. The cylinder kit is 1L3Z 11582-A, It comes with instructions in the box.
Old Jan 13, 2012 | 10:14 AM
chuckyl's Avatar
chuckyl
Thanks for the info,this will make life a little easier. I really appreciate the input.
Tritonstables
Oct 1, 2021 11:46 AM
TexasGuy001
Jul 17, 2012 03:23 AM
Doran
1997 - 2003 F150
Dec 27, 2010 05:26 PM
threedkid
Dec 15, 2010 02:30 PM
sambog
Feb 20, 2005 01:44 PM
