4x4 conversion question.
Old Apr 15, 2023 | 09:14 PM
Bambam0417's Avatar
Bambam0417
3rd Gear
I have a Motorhome on a 2013 E350 chassis. Its 2wd with I beam front suspention. Ive been toying with the idea about converting to 4wd. Would the front suspention of a same year F350 fit on my E350? Or is there a diferent year that would work?
Old Apr 16, 2023 | 05:27 AM
JWA's Avatar
JWA
This site deals extensively with vans that have been converted to 4x4 so give it a look: https://www.sportsmobileforum.com/forums/
Old Apr 16, 2023 | 05:06 PM
hav24wheel's Avatar
hav24wheel
Have to made brackets to bolt the radius arms on, and a track bar bracket.
Old Apr 16, 2023 | 08:41 PM
Hendricks's Avatar
Hendricks
JWA is right, check out the sportsmobile forum for 4x4 swap info.
There is no easy factory parts swap that will end well. the pick up frame is different, so the brackets aren't going to fit.
A lot of the coil spring swaps use a lot of factory parts though (suspension arms, track bar, etc.), so your wear and service parts are easy to get.
I suggest a lot of research and a few phone calls before you start spending money.
I'm happy with ours, but it took a bit of adjustment to get there.
Old Apr 16, 2023 | 09:11 PM
Bambam0417's Avatar
Bambam0417
3rd Gear
Thanks for the pictures! I was hoping there was a radius arm swap. I was thinking that would be the easiest, but guess not. Lol
Old Apr 16, 2023 | 09:13 PM
Bambam0417's Avatar
Bambam0417
3rd Gear
Thanks I will have to look into it. I was hoping that the pickups frames were similar and had radius arms also. But I guess nothing is simple.
Old Apr 17, 2023 | 07:46 AM
Rick1025's Avatar
Rick1025
Contact Ujoint off road. I believe they make a kit to do this.
Old Apr 18, 2023 | 05:22 AM
JWA's Avatar
JWA
Agile off-road as well.
Old Apr 19, 2023 | 06:09 PM
maples01's Avatar
maples01
U-joint off road made a kit to put a front axle on leaf springs in the Econoline.
TallTexAustin
Apr 28, 2021 02:06 PM
75 Camper Special
Mar 23, 2020 01:57 PM
okie pete
28
Oct 5, 2019 12:18 AM
mnnathan
Oct 18, 2010 07:22 AM
Fordfanatic7
Jun 30, 2001 09:09 PM
