5.0 distributor removal problem
Old Apr 14, 2023 | 07:53 PM
Jeff Wecker's Avatar
Jeff Wecker
Having a problem with the getting the distributor out of the 5.0 on my 1986 F150. I replaced a bad TFI module and pickup coil in it. I accidentally stuck it in 180* off after the match marks I made became unreadable. After setting it to TDC I went to pull it back out to reset it to #1 cyl and it will not budge. I can turn it back and forth but it will not pull up and out. I even cranked it over (I can reset TDC easy enough) and it would not pull up. Sprayed PB 'Blaster around the distributor base with no luck. What can I do, to get it out?
Old Apr 15, 2023 | 07:57 AM
Jeff Wecker
*** UPDATE***
I finally got it out.
Old Apr 15, 2023 | 07:33 PM
Beechkid's Avatar
Beechkid
Sometimes it just takes patience and giggling!
glen_melton
Mar 16, 2017 09:59 PM
warren561
Sep 9, 2014 08:42 PM
DemonRace6
Oct 2, 2013 02:05 PM
go2toa
Aug 15, 2006 11:07 AM
jkorreck
Aerostar
May 19, 2004 04:19 PM
