Wiring
Old Apr 14, 2023 | 09:39 AM
ynot321AB1's Avatar
ynot321AB1
Wiring
On a 239 set to 12V, the main wire comes out of the center of the coil to the distributor, my question is it shows another wire coming off of the negative post of the coil and it shows going to the distributor also. Where does the wire from the negative post of the coil connect?
Old Apr 14, 2023 | 09:57 AM
hooler1's Avatar
hooler1
To the insulated connector on the points. This is also where the wire that comes off the condenser is connected. Also on the breaker plate make sure the ground strap is tightly connected to the breaker plate and the screw under the breaker plates. If that's loose, it will drive you nuts trying to track down why your engine is dying under various throttle positions.
Old Apr 14, 2023 | 10:01 AM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
The coil has three terminals - a high tension to the distributor cap; a negative terminal that goes to the switched ground points in the distributor, and a positive that eventually is routed to the run position (through a ballast resistor of not internal to the coil) of the ignition key. This is presuming 12V negative ground with a stock setup.
arthall
Nov 24, 2021 07:50 PM
wmkmun
Aug 17, 2016 08:39 AM
OldgreenF1
Oct 4, 2007 10:07 AM
Rosati
Apr 18, 2005 04:54 PM
F2fan
Aug 12, 2003 10:14 PM
