Sponsored by: Real Truck
Hard Start
Old Apr 14, 2023 | 03:10 AM
Forrest Ashby's Avatar
Forrest Ashby
1st Gear
Hard Start
Need help please. I own a 2002 F250 V10 2v. I bought this truck new off the lot. Recently, I changed out coil packs, plugs, all new pig tails, fuel pressure regulator, throttle body position sensor, idle air control valve, fuel pump and filter, mass air flow sensor and new fuel injectors. Anyhow, after installing the new injectors, my truck now hard starts in the morning and when it has been sitting for a few hours. Fuel pressure is perfect…it’s just not getting a full fuel load. Doesn’t make any sense to me, any suggestions guys? I’m stumped!! No codes, fuel trim perfect. No leaks.
Old Apr 14, 2023 | 12:50 PM
Squisher's Avatar
Squisher
What do you mean exactly by hard start? Is it flooded seeming, like putting your foot in the throttle clears it up/helps? Possibly one or more of the new injectors is leaking down.
Old Apr 14, 2023 | 03:07 PM
Djosbun's Avatar
Djosbun
Push throttle halfway down while starting. Does it start easier? If so you might have an injector bleeding into a cylinder.
Why did you replace all of those parts? Did they all fail at the same time?? You could be creating problems if you’re using aftermarket parts (like non-OEM injectors).
— Dave
Smokinjoe1245
Aug 12, 2022 12:43 AM
stuckstudent
1997 - 2003 F150
18
Jul 18, 2018 07:08 PM
FX4-350
Feb 3, 2014 04:41 PM
travishy
Mar 4, 2013 08:12 PM
fomoco32
Dec 14, 2009 09:34 PM
