Sponsored by: Real Truck
v10 dies when first started
Old Feb 27, 2013 | 12:07 PM
travishy's Avatar
travishy
I have an 02 f350 V10, the past few months I have had to replace several parts including: o2 sensors, replaced exhaust and eliminated catalytic convertor, fuel pump, fuel injectors, all 10 ignition coils with new boots, IAC, MAF, PCV valve, and cam sensor. Now when I first start the truck in the morning it will stall and die, if I turn the key off and restart the engine it will run fine. I have swapped the relay for the PCM for another relay and it still does this. It has never thrown any codes even when it was running on 6 cylinders. I do not know where to go now other than new PCM, which I hope not to take that route. Thank you for the help in advance.
Old Feb 27, 2013 | 12:38 PM
big bad 79 bronco's Avatar
big bad 79 bronco
I would hook fuel pressure gauge up first start truck and then shut it down then watch fuel pressure to see if it drops u could have fuel leaking back to tank or a injector stuck open I will have to look up the spec but it should hold pressure for a while. Next time u cold start truck try cycling key a few times to build fuel pressure then see if it stalls
Old Feb 27, 2013 | 05:21 PM
redford's Avatar
redford
FTE Leadership Emeritus
Hello travishy and welcome to FTE.
A couple of things jump out at me. First, I do not see that you replaced the fuel filter. As Big Bad Bronco suggests, you need to look at a fuel pressure gauge while starting.
The second possibility is perhaps this is related to cold starts, in as much as maybe a malfunctioning temp sensor is not commanding fuel/air mixture to go rich at start? I may not have the sensor name correct, but Intake Air Temp (IAT?) sensor sounds right.
Old Feb 27, 2013 | 06:11 PM
travishy's Avatar
travishy
Thanks for the helpful tips, sorry for I forgot to mention that I change the fuel filter every other oil change. I will try to hook up fuel pressure guage tomorrow. Thanks again
Old Mar 4, 2013 | 02:41 PM
big bad 79 bronco
Did u find a problem
Old Mar 4, 2013 | 05:25 PM
travishy's Avatar
travishy
Yes I did. It was the relay. I checked all the relays with my volt meter and out the bad one in the non uses slot and have not had a problem since. Thanks for the help hope this will help someone else with the similar issue.
Old Mar 4, 2013 | 05:29 PM
Tom's Avatar
Tom
Which relay? For this to be useful we need to know which one it is.
Old Mar 4, 2013 | 08:12 PM
travishy's Avatar
travishy
Sorry the ecm relay was the one that was bad
lwikle
Modular V10 (6.8l)
Jan 8, 2022 04:06 AM
1996fordf-150
Oct 10, 2014 01:03 PM
chrisjb
Jul 12, 2014 04:05 AM
Argess
Modular V8 (4.6L, 5.4L)
Sep 20, 2012 06:01 PM
kwade66
Jun 3, 2006 04:06 AM
