no start
Old Apr 14, 2023 | 10:56 AM
DJE's Avatar
DJE
4wd Low
i wrote them down last night but I forgot to bring them with me to work and I do not want to miss quote them so I will post them this evening. thank you for all your help
Old May 11, 2023 | 08:30 AM
DJE's Avatar
DJE
4wd Low
Hi everyone I know it has been awhile since I posted my question but I wanted to update you all with what i found and thank you all for your help. I ended up having several ball tube o rings that were bad which had eaten away at my upper injector o rings causing a very bad pressure drop. My stand pipe and dummy plugs looked good howerever i replaced them while i was in there anyway just to be safe. once again thank you all for your input.
Old May 11, 2023 | 08:44 AM
bismic's Avatar
bismic
The followup post, with the solution, is greatly appreciated.
Old Jun 7, 2023 | 07:28 AM
DJE's Avatar
DJE
4wd Low
Here is another update. when I went through all of this I decided to replace my hpop just as a precautionary measure well a month after my truck died again and would not build oil pressure so with an air test I heard gurgling from my filter housing so yes a brand new hpop failed in a month. My old hpop was not bad and changing it caused more work in the long run.
Old Jun 7, 2023 | 07:50 AM
bismic's Avatar
bismic
Don't leave us in suspense!
Where did you get the HPOP that failed so quickly?
Old Jun 7, 2023 | 11:21 AM
DJE's Avatar
DJE
4wd Low
it was motorcraft
Old Jun 7, 2023 | 11:23 AM
bismic's Avatar
bismic
Sorry for your troubles.
Old Jun 8, 2023 | 07:06 AM
DJE's Avatar
DJE
4wd Low
Thank you. I just want to keep this info out there and continue to give help to people like has been given to me because I had a difficult time believing that a brand new pumped failed in a month but with a little research it is more common then I would have thought.
ray040ray1
Apr 10, 2023 07:49 PM
Millerfarmsva
Sep 24, 2022 04:38 AM
CrazyCajun
Mar 1, 2020 07:16 PM
Loftatsea
Apr 26, 2016 12:19 AM
Katmandu
32
Oct 24, 2014 11:57 AM
