Fuses
Old Apr 12, 2023 | 08:39 AM
Msaluta's Avatar
Msaluta
Fuses
In trying to diagnose carb issues on my 1979 F100 Custom, I found my electric choke isn't powering on.
I followed the wire through the firewall and found it trying to get power from the fuse panel.
I am once again at the mercy of needing to find fuses for my truck without spending the time/money to convert it to blade fuses.
Does anyone have a source for fuses for our trucks? I'm to the point where I don't care if it's an expense to buy in bulk as I see with Mustang fuse kits in the $50-$60 range for a handful.
I've tried all the automotive stores. The specific voltages and sizes are atypical to anything found in the F100.
Old Apr 12, 2023 | 09:41 AM
Jchet729's Avatar
Jchet729
I saw them at either Lowes or Menards in electrical isle if you have 1 of those nearby. However I didn't look over the selection very closely, just made a mental note.
Old Apr 12, 2023 | 09:57 AM
Msaluta's Avatar
Msaluta
Yeah I saw those too. They're standard glass fuses that don't fit. As an example, I need what appears to be a 6x20mm. Every single fuse kit typically comes with 5x20mm.
Old Apr 12, 2023 | 10:35 AM
Msaluta's Avatar
Msaluta
Found something that appears to be positively reviewed:
https://www.thingsnotable.com/
The best solution is rewiring, but this might work in a pinch while I plan things out.
Old Apr 12, 2023 | 10:44 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Owners manual lists the fuses, the type and Ford part number. Parts catalogs list all of them with specs.
The fuses have a part number and/or the type like AGW-15 stamped on one of the metal ends.
Ford dealers carry glass fuses, as do auto parts stores and every Ford obsolete parts dealer like Green Sales.
Old Apr 12, 2023 | 10:51 AM
Msaluta's Avatar
Msaluta
Using part numbers will probably get me farther than I have, so thanks for that. I spent one (and only) Saturday going to AutoZone, Advance, Napa, RadioShack (there's still one in my town apparently), Lowes, and Home Depot, bringing my little 6x20mm 15A/32V fuse with me with zero success. This seems like a silly problem, because all of them sell standard glass fuses. But the fuses under the dash appear to be non-standard. I'll check out the part numbers.
Old Apr 12, 2023 | 11:21 AM
beardedcap's Avatar
beardedcap
Only luck I’ve had at local parts stores at finding the odd sized ones like the short 15 amp ones are at autozone
Old Apr 12, 2023 | 11:35 AM
NumberDummy
Here's an example of a short 15 amp fuse:
Ford part number: D6TZ-14526-A // Industry part number: AGA-15 or 1AG-15 .. Glass Fuse .62" long // Obsolete // No mm's listed in the 1973/79 Ford truck parts catalog.
GREEN SALES CO. in Cincinnati OH has 20 = 800-543-4959
Old Apr 12, 2023 | 11:56 AM
cwegga's Avatar
cwegga
I don't have a good answer. I have been unable to source some of the harder to find sizes. for my '79. I have checked all the local auto parts stores. The only solution I've found is to order large amounts from fuse manufacturers. I would like to eventually do that and create some fuse kits for our trucks that I can resell to help people out. I guess you could always go with the .22lr fuse replacement solution if ordering from dealers and waiting on shipping doesn't work out.
Old Apr 12, 2023 | 12:11 PM
tbear853's Avatar
tbear853
So, if wired into the cab, is it drawing current in accy too?
njtreefarmer
Large Truck
Dec 30, 2022 04:08 PM
beartracks
Aug 12, 2021 10:45 AM
frdlvr35
Jan 27, 2011 06:32 PM
Danny Stroup
Electrical Systems/Wiring
Feb 3, 2010 06:16 PM
62stepside
Apr 19, 2001 08:45 AM
