I beam identification
Old Apr 11, 2023 | 07:16 AM
CaptainRayPaul's Avatar
CaptainRayPaul
4th Gear
Hello everyone, I have a 79 f100 and I believe the I beams were installed incorrectly. My question is, does the D8TA-8-CA go on the driver's side or passenger side.
Old Apr 11, 2023 | 07:30 AM
Viper Pilot's Avatar
Viper Pilot
The hole that the kingpin drops through should lean towards the rear of the truck.
Old Apr 11, 2023 | 07:52 AM
CaptainRayPaul
4th Gear
The driver side tire is leaning out from the top and is wearing very quickly. I guess the I beam could be bent?
Old Apr 11, 2023 | 09:08 AM
dlburch's Avatar
dlburch
casting D8TA-8-CA should be on the RH (passenger) and the LH (driver) should be D8TA-9-CA
https://www.ford-trucks.com/forums/1...l#post18617421
Old Apr 11, 2023 | 05:18 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Welcome to FTE
RIGHT SIDE // Left Side is D8TA-9-CA .. However, these I-Beams were used on 1975/79 F250 Regular Cabs with Gross Vehicle Weight Ratings of 6200 & 6900 lbs.
Someone needed to replace one or both of these I-Beams, went to a junk yard and didn't know there were different types.
1975/79 F100/150 I-Beams are marked: D5TA-8-FB or GA Right & D5TA-9-FB or GA Left
Old Apr 12, 2023 | 12:59 PM
CaptainRayPaul
4th Gear
Welcome to FTE
This is the I beam that is installed on the driver side(left side) of my F100
Old Apr 12, 2023 | 02:20 PM
NumberDummy
D8TA-8-CA = This is the right (passenger) side.
uk125250
Jul 7, 2017 07:05 PM
bliss1
15
Nov 22, 2007 03:26 PM
triumph_rick
Oct 15, 2006 06:00 PM
tonpartain
Mar 24, 2006 11:09 AM
AWB
Sep 22, 1999 10:34 AM
