Upper front spring retainer clips
Old Apr 5, 2023 | 06:01 AM
Anatta's Avatar
Anatta
Anyone know where I can find a replacement coil spring retainer? The U shaped thing that secures the coil spring in place at the top? I broke one. Thanks!
Old Apr 5, 2023 | 06:39 AM
66with352's Avatar
66with352
LMC has them for 4wd -
Not sure what truck you have - year, 2wd or 4wd??
Is #2 what you are referring to in the link below?
https://www.lmctruck.com/1957-72-for...-4-wheel-drive
Old Apr 5, 2023 | 06:58 AM
Anatta's Avatar
Anatta
Thanks, the truck is a 1966 2WD, but it don’t think those are the right ones based on the picture and location. Mine mount more inward, as opposed to near the outer lip like the diagram shows.
Old Apr 5, 2023 | 08:32 AM
TA455HO's Avatar
TA455HO
Lead Gopher
I can’t get to LMC to compare right now but it sounds like these are what are being looked for.
Old Apr 5, 2023 | 08:38 AM
Anatta's Avatar
Anatta
Originally Posted by TA455HO
Yes, I believe that is exactly what I’m looking for
Old Apr 5, 2023 | 08:45 AM
TA455HO's Avatar
TA455HO
Lead Gopher
C6TZ-5B300-F is the part number. Not reproduced as far as I know. I’ve only ever found the one new pair. I might have one good used one but finding it could be a challenge.
Old Apr 6, 2023 | 09:59 AM
Anatta's Avatar
Anatta
Actually need two of these now as I just noticed that the other one is broken as well.
Also just realized I think I need a new one of the big bolts that connects the radius arm to the I beam, the one that goes up from underneath for the base of the coil spring? Any ideas where to maybe find one of those?
Old Apr 6, 2023 | 10:46 AM
Crop Duster's Avatar
Crop Duster
The fastest way to get those retainers is to make your own. They are just a piece of flat bar with a couple of nuts tacked to it. As far as the bolt goes just go to Fastenal and buy a grade 8 bolt and nut. It ain't like anyone is ever going to see either one of those parts..
mic91F150
Dec 23, 2015 09:12 PM
97ranger xlt
Jan 22, 2007 10:12 AM
WC76TX
Jul 3, 2002 10:56 AM
