Need water pump replacement instructions
I don't have a manual but I'm fairly comfortable with auto repair.
I've pulled the water pump and I'm preparing the surfaces. I plan to replace the pump, belts, thermostat and some hoses. I think I kept the bolts organized as I removed them, because no two seem to be the same length. I don't plan to get into the timing cover.
Where can I find some good instructions for his job?
How specifically do I coat the bolts to prevent coolant leak thru the bolt holes?
My bolts had a fair amount of rust but I cleaned them up and the threads look ok. How important is it to swap out the bolts?
Which permantex should I use - gray or black?
I understand there's a backing plate. Do I HAVE to replace that, or can I go with the old one?
What's the situation with gaskets? Do I need one or two (each side of the backing plate)?
Any other tips?? Thanks in advance.
Never ever use sealer on O rings. I usually use silicone grease. Rubber O rings are usually used where two items may have movement. The soft rubber will provide a seal with that movement. If you use sealer, then you ruin that seal.
I have found people that use gaskets and sealers either have no confidence in the gasket sealing surface or they are too lazy to prep the surface correctly. Again, there are exceptions because sometimes to get the right surface prep, you are going to spend thousands to do it right.
There are gasket adhesives that help hold the gasket in place. Understandable when trying to work on stuff in a car.
One other tip. The sealer that does ooze out is wasted sealer and makes you work look like it was done by a butcher. Anything that oozes out is too much. There should just be a very slight amount, barely noticeable.
You will find there are a lot of different opinions but when it comes down to it, what does the factory do? One or the other but rarely both.
https://www.ford-trucks.com/how-tos/...er-pump-360074
enough sealer for 3 or 4 water pumps was used.
I am like 1Butcher, If there is a gasket no sealer. I will use just a dab of 3M weatherstrip adhesive to hold gasket in place to get a couple bolts started to hold it up in place.
Thanks for the link to the instructions. However those are for 2004 forward. Anybody have a link to instructions for a '91?
Can anybody answer my other questions?
Wire brush, sand blast, evaporust, electrolysis, etc, what ever your favorite rust removal tool & a good coat of automotive paint.
If it is making big flakes, start sourcing a replacement.
I guess my main question is about this backing plate.
I ordered a Gates WP from Amazon. I believe it comes with ONE gasket. However it looks like the factory water pump used TWO gaskets - one on either side of the backing plate. So I need another one? Does anybody have experience with this engine?
My thoughts exactly. I'll clean it up and reuse it.
Does anybody have the torque specs for water pump reassembly, 1991 F250 460 engine? I think that's about all I'm going to need.
I use liquid teflon thread sealer even on the dry bolts
Use gasket adhesive and glue the gaskets to the pump
Leave the block front cover dry, with no glue or sealer
That way, next time you won't have to scrape so much gasket
Strangely, there was no play in my old water pump shaft, so I was perplexed until I examined it closely. The inner seal on the shaft, below the impeller, was completely twisted and partially missing.
Here's what I think happened. I had some leaking hose clamps which lost coolant and introduced air into the cooling system. This broke the siphon between the rad and the coolant bottle. So while I thought I was topping up the radiator, I was only topping up the bottle. My coolant ran low and I cooked the water pump shaft seal.
My first clue was that the heater core started gurgling. It was working fine previously, so I figured it probably wasn't plugged but rather low on coolant. Yep.
I think I got lucky and didn't warp the heads, as it still runs fine.
The internet says Ford big block WP bolts will leak coolant if they aren't coated.
Some say to wrap the threads with Teflon tape. What about coating the shaft? Should I use Teflon pipe dope or tape, or use regular old RTV or Indian head shellac or permantex or what??
I also read that the only bolts at issue are the 4 longer ones. True? Or should I coat all of them?
Someone I known uses this stuff and says it works good.
