This article applies to the Ford F-150 (2004-2014).
What is a water pump? When burning fuel, your Ford F-150's engine heats up to produce motion. To prevent your truck from overheating, your cooling system’s water pump circulates water and coolant to regulate temperature when the vehicle is in motion. But water and antifreeze leaks in the water pump cause damage to the engine.
Materials Needed
Socket and torque wrench
Sockets
Flat head screwdriver
Gasket scraper
Water pump
Gasket sealant
Step 1 - Disconnect the battery
Unplug the negative (black) battery cable from the battery and drain the cooling system and remove the air cleaner assembly.
Step 2 - Remove the obstacles
Unfasten the fan shroud bolts. Use a flat head screw driver to remove the radiator and the bypass and heater hoses. Using the screw driver, turn the hose clamp screw anti-clockwise until the clamp loosens. You will be able to locate the water pump on the engine front. Separate each hose from the water pump. For more detailed instructions on this step, see the related article below.
Turn the bolts connecting the pump pulley to the water pump counterclockwise with a socket, socket wrench and extension with the fan belt in position. Loosen the fan clutch with wrench and rotate the fan, shroud and clutch assembly counterclockwise and carefully disentangle them from the pump. Then unmount the fan drive belt.
Step 4 - Remove water pump assembly
Remove the alternator bracket bolts and power steering pump bracket from the water pump by turning them counterclockwise with socket and socket wrench. You will also need to remove the bolts and pulley connecting the water pump to the timing chain. Pull out the water pump assembly from the engine block.
Step 5 - Scrape off the old gasket
Scrape the engine block where the water pump was with a gasket removing scraper to clean the surface. To replace the water pump, spread a gasket sealer on the water pump mounting surface on the water pump back side and on all mounting bolts.
Step 6 - Install the new water pump
Figure 6. Install water pump.
Place the water pump gasket on the water pump and align the bolt holes with the pump and gasket. Mount the water pump onto the engine block, and fasten the pump bolts by hand in clockwise motion and use a socket and torque wrench to tighten them.
Step 7 - Place parts back in
Figure 7. Place everything back in.
Replace alternator brackets, power steering pump, brackets, radiator, and heater and bypass hoses in that order. Then fasten the hose clamp screws in clockwise motion with the screwdriver for tightening. Then install the fan shroud, fan pulley and spacer and fan. Then mount the fan drive belt with specified tension and tighten the alternator bracket.
Step 8 - Fill the cooling systemFigure 8. Fill with coolant.
Fill the cooling system with the specified amount of water and antifreeze and connect the negative battery cable to the vehicle's battery.
Pro Tip
Ford F-150 owners in forums argue for replacing the fan clutch when the water fan is replaced because the two share a rotating axis. This is because an out of balance clutch can destroy a new pump.
Water Pump
How to Replace Water Pump
A water pump is a vital component to the well being of your vehicle's engine.
This article applies to the Ford F-250 and F-350 Super Duty (2005-2014).
When burning fuel, ...
How to Replace Your Timing Chain
Timing chains, tensioners, and when to start worrying about changing them.
Your F-250's timing chain ...
Ford F150 Replacing Power Steering Pump
How to Replace Power Steering Pump
nstueve, sne97hd
A little cheese with that whine?
This article applies to the F-150 (1987-1996).
The power steering pump provides the ...
How to Replace Your Radiator
If your radiator is not cooling your Ford F-150 properly or if you need to replace it with a better one, it could be a costly process. Here is how to replace it yourself.
This article ...
How to Replace Radiator
The radiator is key to keeping your engine running, so you'll want to replace your radiator as soon as you find out its faulty.
This article applies to the Ford F-250 and F-350 Super Duty ...
How to Flush Radiator
Frequently changing the radiator's coolant ensures that your engine runs at its best.
The coolant in the F-250 or ...
