horn brush question
Old Nov 16, 2003 | 09:02 PM
cajunbull61's Avatar
cajunbull61
horn brush question
I'm rebuilding the steering column on my 66 F100. The prior owner disconected the horn button and added an auxillary button on the side. My question is this, do I need two horn brushes? One for the steering wheel and one for the socket under the steering wheel The only diagram I've seen was in a catolog and they only showed one brush. It wasn't very clear asa to were it went. Any help on this will be appreciated.
Thanks Cajunbull61
Congrats to Matt Kenseth and the #17 Dewalt Ford on their Nascar Championship
Old Nov 16, 2003 | 09:38 PM
AgH's Avatar
AgH
I'm in the same process of rebuilding (correcting) a 1966 F-100 steering column. The PO removed the guts, including the horn brush, when he installed a small steering wheel and added a horn button under the dash. From what I remember from my old '69 F-100 years ago there is only one horn brush. The brush should be located in the plastic turn signal housing mounted in the steering column collar. From here it should transfer the power to a horn ring mounted to the steering wheel and on to the steering wheel horn button. My manual doesn't have a very good diagram but I'm going from previous experience from about 15 years ago when working on my '69. Hope it works for you. I'm still trying to figure out why I don't have power to my horn, turn signals and brake lights.
Old Nov 17, 2003 | 11:10 AM
smcafee's Avatar
smcafee
My '65 250 has two brushes. One goes in the turn signal switch assembly and makes contact with the steering wheel. One goes through the steering wheel and makes contact with the horn ring.
xrsfsho
Oct 9, 2015 10:29 PM
Green72F250
Jun 26, 2014 02:40 PM
centralNH
Mar 17, 2014 08:51 PM
gangstakr
Feb 3, 2014 01:29 PM
shakespearesdad
Apr 29, 2008 04:46 PM
