Engine ID help
Old Mar 29, 2023 | 02:47 PM
F100-59's Avatar
F100-59
8th Gear
Engine ID help
Hi guys. Here is my engine that came with my 59 frame. The block code is C8AE 6015 AC I'm looking at pix to see what it may be but I'm not seeing a lot with the intake on the driver's side. Looks like a 223, but with a 68 block code ? Could it be a bit of mix and match ? Any thoughts appreciated.
Old Mar 29, 2023 | 05:15 PM
85e150's Avatar
85e150
223. There is no mix and match between those and the later 240/300.
Maybe its C3AE.....
Or--long shot--a replacement block cast in '68. But that's beyond the 24 and 36 month warranties of that era. Industrial?
Best bet is it's C3, just so crusty it looks like C8.
Look for the date code cast into the block. See:
https://www.ford-trucks.com/forums/1...l#post16485189
Old Mar 29, 2023 | 05:46 PM
Kruse's Avatar
Kruse
Off topic...a little bit, but what brand of starter came with it?
Old Mar 29, 2023 | 06:07 PM
F100-59's Avatar
F100-59
8th Gear
That's the stuff. Got out my mini wire brush and cleaned it up and it is C3. Which makes the date stamp of 4B18 way more sense lol
Old Mar 29, 2023 | 06:13 PM
F100-59's Avatar
F100-59
8th Gear
@Kruse, Fram is new to my so I'm just digging into it. Its an 87ish AOD trans with a custom adapter. So my guess is its stock to that trans. Here is a better pic.
Old Mar 29, 2023 | 07:20 PM
85e150's Avatar
85e150
The AOD is a delicate flower and usually needs a throttle valve properly adjusted to shift right and not burn up.
So when you get to that point, check that out.
Swerving suggestion.....
Old Mar 30, 2023 | 08:00 AM
hiball3985's Avatar
hiball3985
The engine is 60-64. A 59 or earlier would have a valve cover with two studs rather then bolts on the perimeter. So the C3 number makes sense.
Old Apr 6, 2023 | 09:18 PM
JohnNewb's Avatar
JohnNewb
Good catch on the valve cover.
Old Apr 10, 2023 | 06:40 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
223 was used in passenger cars and trucks from 1954 thru 1964. The intake/exhaust manifolds are on the left (drivers side) of the engine.
Renopony67
Mar 25, 2022 09:13 PM
cope652
Large Truck
Jun 5, 2021 01:24 PM
Kahunajohn
Jan 1, 2015 11:52 PM
frostedto
Mar 21, 2011 03:31 PM
Jeff3298
Engine Swaps
Apr 26, 2008 10:15 PM
