What is this?
Old Mar 25, 2023 | 10:34 PM
wpg_250's Avatar
wpg_250
What is this?
I figure some kind of temp sensor that was used before the SCT unit was installed, but can't figure out the snowflake purpose? Any ideas fellas?
Old Mar 26, 2023 | 05:48 AM
Mcrafty1's Avatar
Mcrafty1
It's a thermometer, the sensor is place externally, Usually behind the front bumper to get it as low as possibly to the road surface to let you know what to expect for freeze conditions while driving. Helps take the guess work out of black ice and such.
Old Mar 26, 2023 | 12:04 PM
wpg_250's Avatar
wpg_250
Huh, well that's something I've never heard of before. Truck has an 8'' lift so not sure how effective it would be even if it was working and still puzzled by the IN/OUT part?
Old Mar 26, 2023 | 09:46 PM
hosegp's Avatar
hosegp
Maybe it stands for inside/outside. I see an I and an O on the top left and bottem left corners. Are those buttons that might switch between an external sensor and a sensor built into the unit (maybe behind those slots above the snowflake)?
Old Mar 26, 2023 | 09:58 PM
2004 F450's Avatar
2004 F450
Probably needs new batteries.
Old Mar 27, 2023 | 04:58 AM
tjc transport's Avatar
tjc transport
i ain't rite
^^^ this^^^
it is an aftermarket indoor/outdoor thermometer.
toggle the switch on left side up shows temp inside the cab. toggle it down and it will show outside temp.
the three little openings in the case above the "snowflake" let air into the case to read inside temp.
Old Mar 27, 2023 | 10:16 AM
wpg_250's Avatar
wpg_250
Originally Posted by tjc transport
^^^ this^^^
Ok makes sense. Well it's outdated and no use to me so in the garbage it will go. Backtracking the cord could be fun times lol.
Thanks
Old Mar 27, 2023 | 05:15 PM
Mcrafty1's Avatar
Mcrafty1
Thanks
Slide your hand as far down the wire as you can and snip the wire off and forget about, it isn't connected to an power source.
351bolt
Large Truck
Apr 20, 2015 03:35 PM
alienbogey
Jan 1, 2014 06:32 PM
shotgun2
Sep 14, 2012 02:39 PM
idahodisco
Mar 15, 2010 11:14 AM
PAUL_2
Mar 22, 2001 11:26 PM
