Temp sensor option
Old Sep 14, 2012 | 01:42 PM
shotgun2's Avatar
shotgun2
Temp sensor option
I have a F100 1978, 300 I6
the temp sensor is all chew up, (i did it)
where else can i put a Temp sensor?
what is the aftermarket option?
Thanks
Old Sep 14, 2012 | 02:04 PM
HIO Silver's Avatar
HIO Silver
The ideal place is on the thermostat housing.
What do you mean by "aftermarket option"?
Old Sep 14, 2012 | 02:06 PM
shotgun2's Avatar
shotgun2
Well, they sell all kind of various oil gauge, so i thought maybe they do the same for Temp sensor?
G
Old Sep 14, 2012 | 02:26 PM
fmc400's Avatar
fmc400
MSEE
A replacement sending unit should be available at most parts stores. Alternatively, as you imagine, you can get an aftermarket gauge (which I recommend anyway).
Old Sep 14, 2012 | 02:39 PM
HIO Silver's Avatar
HIO Silver
G
Oh, you mean mechanical vs electric.. a mechanical gauge consists of a capillary tube to sample the fluid instead of a resistance-based sensor as with the electrical.
Yeah, water temp gauges can be either mechanical or electric. Your call on which way to go. On the street, most opt for an electric water temp gauge system.
Dunno about yall but I would rather go with electric... pop/burn the capillary tube and ya either end up with hot oil (fire) or hot coolant (scalding?) in the engine compartment or in the cab. On race cars it's not so much an issue since there are fire/safety personnel nearby.
rtaylor6801
3.7, 3.5 and 3.0 Duratec V6
Sep 28, 2017 06:50 PM
351bolt
Large Truck
Apr 20, 2015 03:35 PM
seck
Feb 28, 2011 06:02 AM
Sharpshooter77
Sep 16, 2007 06:37 AM
