Ignition switch issue?
Old Mar 20, 2023 | 06:17 PM
tfunk88's Avatar
tfunk88
Hi, thanks in advance for any help!
Drove my 05 Excursion in to work today. All was good. Leave work to go to a Dr appointment. Still perfect! Finish at the Dr, get in the truck, turn the key to run, glow plug light goes out, turn the key and…nothing. I mean absolutely nothing. No click, no change whatsoever. Even the radio kept playing, no temporary pause like it does normally when starting. The key does turn past “run”, but only slightly…has springiness but I’m honestly not sure it’s turning as far as it normally would.I pulled the ignition switch and it seems absolutely fine. Put it back in and same thing.
Leave the key in “run”, pull starter wire and touch positive battery terminal…truck fires right up. I’ve checked lots of fuses, but to no avail.
Old Mar 21, 2023 | 03:26 PM
tfunk88's Avatar
tfunk88
Problem solved!
So, back in August I had to pull the dash and steering column covers for some reason…don’t even remember why now. Anyway, the plastic clip for the “key in ignition” chime broke when I did this. I found a part of it on the floor and couldn’t find the other part. I assumed I just couldn’t find it. Well, apparently it was down in the space where the cylinder lock goes and took 8 months to find its way into a crevice, stopping the key from turning all the way. Found it when I pulled the cylinder again today. 😂
Old Mar 21, 2023 | 08:17 PM
BryanStein's Avatar
BryanStein
Thanks for the followup post solving the problem. Not many do this.
Old Mar 22, 2023 | 11:17 AM
tfunk88's Avatar
tfunk88
Ha yeah, there have been several threads where I have a similar issue and they never mention the resolution. Decided I can’t be a tease lol
SouthernBlues
Mar 15, 2015 08:56 PM
95xltthumper
Oct 5, 2014 11:32 AM
Skuvas
Jan 12, 2013 06:44 PM
rmosso1
Jul 13, 2009 04:04 PM
csb912
May 10, 2007 01:04 PM
