E99 SD Crank No Start, Smokes.
Old Mar 19, 2023 | 09:22 PM
‘99Powersmoke's Avatar
‘99Powersmoke
Hey all, as the title states, I have an early 99 F-250 SD with the 7.3. It’s recently had an issue with a crank-no-start. Before this, it would always start, but as the days went on, the cranks got longer, and after sitting a few days, (and declining maybe 20 degrees, down to about 40F), it became a no start.
The truck cranks just fine, new starter, strong batteries, zero blow-by, billows white smoke out the back, new glow plugs (about 4K miles on them) and the GP’s are pulling roughly 120 amps.
After letting the glow plugs run about 40s, I’ll try to crank over the truck. It cranks strong, and you can hear it skip like it’s about to start. There’s clearly fuel getting into the cylinders, but it sometimes mid-crank stops smoking, like it ran out of fuel, but returns to smoking after a second. It acts like there’s bad GP’s, despite pulling significant amps.
Previously to this, I had let the truck sit for a few days, maybe 3 max, and when I started it, it took a bit long to crank and acted like it had air in the lines. I had put a new lift pump in the truck, but had tightened everything afaik. Is it possible that it’s just an issue with air in the fuel lines? I had opened up the fuel bowl and it “popped” kinda like a soda can. Is that normal? A decent amount of fuel bubbled out when spinning the cap back on. Is it possible the truck just has a loose fuel fitting and is introducing air into the system, causing a no start?
Unplugged ICP - no change
Unplugged MAF - no change
Confirmed Good CPS
Normal ICP values
EOP values correct
IPR reads 38% while cranking
EBPS is unplugged, and the EBP tube is unsalvageable, so EBPS is disabled for now.
Old Mar 19, 2023 | 10:24 PM
S-squatch's Avatar
S-squatch
I'm sure others will drop in, but you shouldn't need glow plugs to start in those temps.
Old Mar 19, 2023 | 10:44 PM
‘99Powersmoke
That’ll make diagnosis a bit easier, then. Rule out the GP’s. Got it. I’m mostly focusing on the fuel system right now. I don’t think it’s a sensor thing just cause the truck ran perfect days earlier without a hiccup, and readings don’t show anything wonky.
hobohilton's Avatar
hobohilton
A bit confused about "air in the lines". Excess fuel is returned to the tank so air should be purged out rather quickly while it is running.
Is the engine oil level up to the full mark ?
Is the block heater working ?
Age of the GP's ?
Bad ICP
Old Mar 19, 2023 | 11:13 PM
‘99Powersmoke
Age of the GP's ?
Bad ICP
When I mean “air in the lines” I mean the lines from the fuel bowl to the injectors. As far as I’m aware, the 7.3 is a “dead head” system, where the bowl returns fuel to the tank, but the injectors pull from the bowl and don’t return anything. So when you introduce air in the system, you have to actually run the truck to bleed the air out of the injection lines. I’ve done this before after running the truck dry a time before. It usually takes a few miles to get ‘er going right, but after that it’s set. Runs rough and barely had any power, and you pretty much have to floor it a few times down the road and run it through its paces to get it out. Pretty annoying, but it works.
as far as your questions, glow plugs are about 4k miles, or about 8 months old. Block heater’s cable’s broken, engine oil full, and the ICP has a little oil in the plug, so I’ll be replacing it soon anyways, but unplugging changes nothing, and it reads normal on the scanner.
Old Mar 20, 2023 | 05:52 AM
udsuth78's Avatar
udsuth78
If temps are in the 40's and 50's then glow plugs are necessary to start most 7.3's. You said the system is pulling a lot of amps. Are you measuring the load and if so how many amps is it pulling when first turning the key? Have you tried letting the plugs cycle a few times before cranking? You can watch the voltmeter in the cluster and it will climb when the plugs have finished a cycle. Then just turn the key off and back on again.
Old Mar 20, 2023 | 06:52 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Have a look at the following links taken from the 7.3L PSD Tech Folder.
Old Mar 20, 2023 | 07:45 AM
S-squatch's Avatar
S-squatch
I stand corrected, I'll rephrase my 7.3 starts just fine in those temps without glow plugs.
Old Mar 20, 2023 | 10:41 AM
knottyrope's Avatar
knottyrope
there is a return for the air that you might have an obstruction since the cover popped like a soda can
Old Mar 20, 2023 | 12:45 PM
udsuth78's Avatar
udsuth78
If it's ran previously that day, yeah you're right they will typically pop right off. Now if they've sat overnight or a few days for sure they need a little help, in my experience and some of the reading I've done here. Just not enough heat to get the party started w/out glow plugs setting the mood.
mhaines15
Jan 28, 2022 06:13 AM
BaldKnob
Jan 9, 2022 08:41 AM
CaptainCook1987
Dec 29, 2021 08:36 PM
CaptainCook1987
Dec 28, 2021 05:11 PM
jmd4993
Apr 2, 2020 02:53 PM
