Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
1971 c750 Coe decode please
Old Mar 17, 2023 | 06:35 PM
51F5MH's Avatar
51F5MH
Found another orphan. A 1971 C750 has found a new home
Could I please get a decode on this new to me truck? Thanks!
Old Mar 18, 2023 | 01:26 AM
85e150's Avatar
85e150
Tomorrow......
Old Mar 18, 2023 | 06:19 PM
85e150's Avatar
85e150
C76 = C750 gas
F = 391 4V FT gas V8
V = Kentucky Truck Plant
H12454 = 1970 numerical series, December 1969 production
135 = 135 inch wheelbase
No color code. Note the truck is a special order and color could have been part of it. Looks like it was yellow, now blue....
C760 = C750 gas, 27,500 lbs GVWR
4A8
4A = Black with Blue/Parchment/Black/Red/Ivy leather grain H.D. vinyl
8 = Custom Cab without sleeper
Y = Transmatic model MT-40 four Six speed Allison automatic transmission. The MPC says 6 speed, but they may be counting TC lockup or....? SEE EDIT note below
No rear axle code, again probably part of the special order.
N = Ford-Rockwell (Timken) 9,000 lb capacity front axle with power steering
27500 = 27,500 lbs GVWR
199 3800 = 199 certified net HP @ 3800 RPM
A60114
A6 = Ford of Canada, Western District Sales Office
0114 = Special Order Number, a sequential number for the model year IIRC.
Was this a fire truck?
Let me know if something doesn't line up.
I note you say it's a '71. There may have been a delay in getting it on the road, and it may have been titled as a 1971 by the time it was ready. Not right, but not unusual to see.
Old Mar 18, 2023 | 08:30 PM
51F5MH's Avatar
51F5MH
And now it's white! Thank you 85e150! Not a fire truck. As it sits now it's a grain truck. It has 63,000 miles on it which is high for a farm truck so it probably did have a previous life. I haven't got the truck home yet. It's in a field with about 2-3' of snow on the ground so I'll have to wait a while before I can get it home. As soon as calving is over I'll ask the previous owner what the trucks history is. It was previously registered as a 1971. I thought the Tranny console showed a 6 speed but I could be wrong. Any idea what the tag (70 / 505) is below the data tag?
Thanks for the help! More info to come once Over Easy is home and I've had a chance to talk to the previous owner.
Rab
Old Mar 18, 2023 | 09:26 PM
85e150's Avatar
85e150
OK I misremembered on the transmissions. Some later transmissions are said to be 6 speeds, but Allison lists them as 4. Apparently, the MT-40 was a legit 6er. That's good, as four speeds is just not enough.
Reference info, about post 8 it gets into the 4 vs. 6 etc:
https://www.ford-trucks.com/forums/1...ssistance.html
As to the 70/505 tag, that's from a prior owner, not Ford. Unit number? Some way to ID the truck for their records
Old May 5, 2023 | 03:26 PM
51F5MH's Avatar
51F5MH
Got Over/Easy home now. Truck is in really good overall condition. The cab is a bear to lift up. Do the springs go bad in these trucks? And they couldn't find the keys!! Can I get keys cut from thw vin?
Sofkee
Large Truck
Jun 11, 2022 02:49 PM
mreams
Large Truck
May 20, 2022 08:10 AM
usmcpat
Large Truck
20
Mar 26, 2022 10:38 AM
Jailguard811
Large Truck
Aug 26, 2021 05:35 PM
cwolff
Large Truck
Aug 21, 2021 12:02 AM
