Torque converter lockup?
Old Mar 16, 2023 | 06:45 PM
GreaseMonkey519's Avatar
GreaseMonkey519
4wd Low
I am working on a 97 F250 Powerstroke. 300k on the engine and chassis with around 50k-65k on an ATS stage 4 (?) Transmission with the on command controller. I have an intermittent torque converter lock up, and/or partial lockup. Local transmission shop said that the truck is not showing turbine speed, or output speed. What's the best source for wiring diagrams and trouble trees for these trucks? Or would it be worth it to invest in the US Shift Quick 4 stand alone controller and be done with it. Thanks for the future input.
Old Mar 16, 2023 | 08:55 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The E4OD in your truck has neither a turbine speed sensor nor an output speed sensor. That's probably why it isn't showing those two speeds.
Old Mar 16, 2023 | 10:04 PM
GreaseMonkey519
4wd Low
Well, that goes to show how much I know about these trucks. What would cause the torque converter to not go into full lockup? Speedo is working, cruise works, no ABS light on, or flashing O/D light. The only code that he could pull was a P0500. I changed the sensor in the diff, it didn't change anything.
Old Mar 17, 2023 | 07:43 AM
z31freakify's Avatar
z31freakify
Check wiring going to the VSS as well as the connector. Also make sure your brake lights are working including the cab brake light.
Old Mar 17, 2023 | 07:47 AM
Briansshop's Avatar
Briansshop
FYI, I've had US Shift controllers in 2 trucks,very happy with.
Old Mar 17, 2023 | 01:15 PM
Mark Kovalsky
That can cause this. Check the wiring to the sensor electrically for continuity, short to power, and short to ground.
Kintla
Oct 2, 2022 06:16 PM
HKusp
28
Dec 23, 2015 08:58 AM
onepieceatatime16
Sep 14, 2014 10:47 PM
ladelld33
Sep 10, 2014 04:38 PM
pops_91710
Aug 13, 2005 02:34 PM
