Coolant leak
Old Mar 15, 2023 | 03:23 PM
vettman's Avatar
vettman
Coolant leak
Just pulled the radiator on my 1976 F350 460/C6 after noticing coolant on floor below radiator. Just got a call from my ace radiator repairman and he said the radiator does not have a leak, even at 20psi. He had it pressurized for 24 hours. Given it's not the radiator, he says it's probably the water pump. Prior to removing the radiator I tried to determine where leak was coming from. The coolant was dripping from the bottom of the center of the shroud, and the center of the back side of the radiator appeared to be wet. Now would a leaking water pump allow coolant to show up where I've described? I have a water pump on order and a new backing plate, gaskets, etc. I've done this job once before, but if it's not leaking I sure don't want to do it again. Since it's not the radiator I guess it would have to be the water pump--right?? All suggestions/comments appreciated. Thanks
Old Mar 15, 2023 | 05:31 PM
f5fordgirl's Avatar
f5fordgirl
Could be a hose, and the timing cover on 429 and 460's tend to corrode through.
Old Mar 15, 2023 | 05:59 PM
mark a.'s Avatar
mark a.
Could be any number of things. If you can't see it then your going to need a rad a psi tester. Test the cap too. Avoid dies they make a hell of a mess.
Old Mar 16, 2023 | 10:33 AM
beartracks's Avatar
beartracks
Hose clamp
Old Mar 17, 2023 | 08:32 PM
Ozzie H.'s Avatar
Ozzie H.
On a pressurized system sometime coolant can "squirt" to somewhere other than what's leaking. Be sure to do a good identification of what's leaking before tearing into it.
RENTHAL2749
Modular V8 (4.6L, 5.4L)
Apr 22, 2014 12:16 PM
DmanNC
Dec 22, 2013 07:57 PM
mdbiofuels
May 31, 2012 11:22 PM
caperail
Nov 20, 2004 05:41 PM
Simek
Aug 24, 2004 01:10 PM
