Piece inside the frame identification
Old Mar 15, 2023 | 05:11 AM
tlien's Avatar
tlien
It’s not the best picture I know but on the drivers side of the frame right infront of the shock and mount is a large hole. Looking inside there appears to be a piece of metal aside from the bolts running through it. Is this just frame support? It looks like it’s pretty rusty and starting to crumble from dirt buildup but the rest of the frame around it is good. What exactly is it and should I be concerned? The other side looks fine thankfully
Old Mar 15, 2023 | 06:24 AM
mark a.'s Avatar
mark a.
It's a brace to keep the shock tower bolts tight. Without it the bolts would just crush the two sides of the frame together and never stay tight.
Old Mar 15, 2023 | 12:27 PM
tlien's Avatar
tlien
Is there a hole behind the shock tower mount then that allowed ford to put that there when installing the shock towers? Is it possible to buy a new one? Or should I just let it be
Old Mar 15, 2023 | 06:03 PM
mark a.'s Avatar
mark a.
If the frame is ok around it I wouldn't worry about it.
Old Mar 15, 2023 | 06:40 PM
tbear853's Avatar
tbear853
Not a crack is it? Maybe it rubs off?
Old Mar 15, 2023 | 07:54 PM
tlien's Avatar
tlien
Thankfully no it’s not a crack. Just grime that got disturbed. The frame has rust holes but my local welding shops gonna go to town on it and fix it for me when I take the cab and bed off
Old Mar 17, 2023 | 10:04 AM
speedfreak78's Avatar
speedfreak78
This is the second post you've made about rust issues with this frame. The front section of frame is boxed and there are a few pieces of boxing and bracing inside it that will trap moisture/dirt/salt/etc. My '79 plow truck was rotted from the inside and snapped the frame, but it wasn't too bad on the outside. When I finally parted it out i cut the front frame apart and could crush all those internal braces and boxed sections by hand they were so rotted.
I said it in the other post, but you need to do a thorough inspection of this frame. IMO, just from the pics I've seen, you're gonna be time and money ahead by finding a good frame, even if you need to get one shipped in. It might be more expensive up front, but it will also make the swap multiple times easier when you can unbolt a part, clean/restore it and just bolt it back on a second frame. The time saved having to disassemble a whole truck, clean/restore/catalog/store all the parts, have the frame repaired/restored and then re-assemble it all would be well worth it, IMO
flowney
657
Mar 4, 2026 10:39 AM
1low50
24
Feb 13, 2021 07:53 PM
trusty79
Maryland Chapter
32
Jan 25, 2011 08:03 AM
Goobzilla
Oct 8, 2004 11:10 AM
cigarxtc
Garage & Workshop
Apr 13, 2003 04:44 PM
