Steering Column Freeplay
Old Mar 15, 2023 | 12:18 AM
Josue_VHS's Avatar
Josue_VHS
Trailering
1978 Ford F100; inline six / 300 block w/one barrel carb
There's about six inches of wobble on the steering wheel/column. Not sure what's causing this or how to adjust it? I can turn the wheel about 120 degrees before it even starts to turn the rack/wheels. I think something is wrong with the steering gear box somehow? I honestly have no clue how to fix this.
Old Mar 15, 2023 | 06:03 AM
LandAndStone's Avatar
LandAndStone
Desk Jockey
There are lots of causes to look into. Ultimately, it is probably the steering box and your tie rod ends. These are common places to start, but by no means a complete list.
Check out a few of the threads on FTE.
https://www.ford-trucks.com/forums/1...ng-causes.html
Old Mar 15, 2023 | 08:15 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
You do NOT have a "rack", that is a term used when a vehicle has a "rack and pinion" steering set up. Read up on that thread in the above link and do some inspections.
Wobble on the steering wheel itself is a sign of the upper and lower bearings be worn out, mostly the upper. Order a bearing and take it apart and replace it. There is a lower plastic cover. You can order a aftermarket bearing that will fix the play down there.
If the whole column itself is loose, check the 2 bolts that holds it to the dash. It should have a plastic cover over the 2 bolts. 4 screws hold it on, then it also snaps around the column.
For the play in the steering box itself. Inst the rag/flex joint between the steering shaft (coming out the fire wall) and the steering box input shaft. If it is good, then it sounds like a common worn out steering box. Replace it with a QUALITY one from Red Head Steering or Blue Top. NOT a local parts house one either.
Old Mar 15, 2023 | 08:33 AM
hobohilton's Avatar
hobohilton
I would start here
https://offroadpowerproducts.com/red...ford-f150.html
Old Mar 15, 2023 | 11:02 AM
tbear853's Avatar
tbear853
Is the wheel wobbling on the column top ...or is it simply a lot of turning that doesn't turn the front wheels ... or both? You don't have a rack.
Just an idea here, but put a pair of gloves on and lay in front of the truck parked with wheels straight ahead ... so that you are looking at the steering linkage, tie rod ends, drag link. Have a friend, wife, GF, SO, etc ... sit in the cab and rotate the steering wheel through this free play zone, back and forth. Note what doesn't move.
After getting a look, place a gloved hand in safe positions to feel for any movement between suspect parts at various ball type joints like at tie rod ends, drag link, pitman arm. Engine is off. You are looking for lost motion, to answer the question ... "why the wheels aren't turning right vs left while the steering wheel is."
Old Mar 15, 2023 | 11:51 AM
LandAndStone
Desk Jockey
Words of wisdom from tbear. Well said.
Old Mar 15, 2023 | 11:59 AM
1964 Model's Avatar
1964 Model
Lots of possibilities here. Probably worn parts, with its age and miles.
Start by having some one shake the steering wheel and see where the play or lost motion is coming from.
Could be in the tie rods, drag link or even king pins. Also there is a damper screw on the top of the steering box that has a lock nut.
The lock nut can be loosened and the slotted screw turned clock wise. The slotted screw has to be held with a large screw driver, while the nut is snugged up.
This can take some of the lost motion out of the box, but be careful not to over tighten it.
Old Mar 15, 2023 | 12:04 PM
hobohilton's Avatar
hobohilton
__________________________________
Best to try that trick with the steering wheel turned one way or the other to where is is locked at the end of the stroke.
Tightening that adjustment with the wheels straight is where most of the wear is. Snugging it there will jam it when it is turned to the end of it's stroke.
Old Mar 15, 2023 | 12:09 PM
tbear853's Avatar
tbear853
Be very careful. To tight can jamb one, or even break it.
1956in1956
Jun 3, 2022 11:37 AM
mytoolman
Dec 23, 2021 02:06 PM
wrd0225
Aug 23, 2016 04:17 PM
Johnny Be Cool
Apr 1, 2015 04:28 PM
mfire138
Aug 12, 2008 07:08 PM
