PCV and breather setup?
I'm getting my 292 sorted, and I'm looking to add a PCV and breather to it. I found these, and I think I will go with them as they seem to check all the boxes and have a bonus retro look.
These are bolt-on Breather adapters that are baffled.
Breather Adaptors (12bolt.com)
Summit sells a push-in breather that has a PCV valve, and you can get the other one as just a breather. Here is the one with the PCV valve in it.
Speedmaster PCE314.1012 Procomp Electronics Valve Cover Breathers | Summit Racing
I wanted to see if anyone has an opinion on this setup or can point out any gotchas with it.
As always, you guys are great, and thank you in advance.
Paul
https://www.ford-trucks.com/forums/8...g-a-pcv-2.html
