pcv and breather location
Pcv should be located in the rear passenger side valve cover. Breather element should be located in the air filter box.
Edit: I only recommend an OEM, Motorcraft PCV valve. No other alternative since it may allow for more vaccum through the valve. The PCV valve is a metered vaccum leak. I have used several different types. Each performed @ or below value. It's $7 for a Motorcraft.
Here's a link and you can just type in "How to test PCV valve?" in Google for many related posts.
http://www.autoshop101.com/forms/h63.pdf
This link also gives very good info. Positive Crankcase Ventilation (PCV)
tex_mex1911
11-11-2016 06:08 PM
phurst
01-06-2011 06:07 PM
TexasGuy001
17
06-26-2009 11:25 AM
joditruck
12-29-2007 09:06 AM
