EGR plate
Old Apr 15, 2023 | 06:36 AM
Franklin2's Avatar
Franklin2
The engine does not need the EGR to idle correctly. In fact that is what a bunch of those hoses and wires where for, to specifically turn the EGR off at idle so it will not mess the idle up and cause it to stall. With the EGR gone, you might get a little engine ping on a hot day, not much else. And that can be tuned out.
Have you adjusted the idle mixture screw on the carb?
Old Apr 15, 2023 | 06:37 AM
FuzzFace2's Avatar
FuzzFace2
Originally Posted by SeanTi
So I just put in my rebuilt 300 6 in my 1980 F100. There are no emissions left on the motor. When I pulled the engine apart I removed and plugged the EGR tube from the exhaust manifold to the EGR plate. The engine runs great except at idle. The engine shakes like crazy to the point if you drive in 3rd at 1000 rpm the truck bucks.
It could be my rebuilt carb I put on in July is already shot. Or my question is could the truck need the pressure from the Manifold to the EGR plate to even out the carb? the truck has no computer it’s bare bones. I replaced everything in the ignition system with stock parts.
If you went thru this post just above you will see my 81 F100 w/.300 has the smog removed as well and idles smoothy.
It will pull from about 1000 RPM in 4th gear or a little higher RPM, (35 MPH) in over drive with out bucking.
I would say you either have a vacuum leak or the EGR port is not plugged causing a vacuum leak.
Did you leave the EGR plate in place with the valve on the end and just remove the vacuum hose or ???
I would start looking for a leak between head & manifolds. You running EFI EXH manifolds or the factory log?
If EFI there is some work needed to get them to seal as the lips the washers hit are at different hights to will not pull tight evenly.
B TW I am running EFI EXH manifolds with the factory intake & carb.
Dave ----
cad ford-1958
13
Aug 31, 2022 10:16 AM
cherrybomb37
Jan 22, 2015 12:34 AM
morrowtruth
1997 - 2003 F150
Nov 17, 2008 04:39 PM
bob1987f
Nov 28, 2007 03:04 AM
etcetera
Modular V10 (6.8l)
Jan 3, 2005 09:27 PM
