Third Tail Light Issues
Old Mar 11, 2023 | 09:29 AM
Caleb H's Avatar
Caleb H
Hey everyone,
Here's the deal. I have a 2011 Ranger XLT Extended Cab. When I turn on the light switch, everything comes on normally EXCEPT the third tail light (center high mount). However, when I press the brakes, all three brake lights function properly. The assembly only has one single-filament bulb in it, and I verified the bulb is fine (and I swapped a brand new OEM one in anyway just in case). I disconnected the wiring connector and made sure it was free of corrosion or any other foreign material, and it was. I cleaned it up anyway. Still the same problem, and inspection is coming up this week. I own a multimeter but my electrical diagnosis skills are woefully limited. Does anyone else have this issue? Have I owned this truck for 12 years not knowing that is only a brake light and not a running light? What's going on?
Old Mar 11, 2023 | 10:10 AM
pawpaw's Avatar
pawpaw
Your correct, sounds like the high mount brake-lamp is working normally, as it only lights up when we step on the brake pedal.
Old Mar 11, 2023 | 02:07 PM
Johnny Paycheck's Avatar
Johnny Paycheck
Several years before the end of the Ranger run, the cargo lamps got dropped from the standard equipment.
You definitely only have a brake lamp up there.
Old Mar 11, 2023 | 06:39 PM
Caleb H's Avatar
Caleb H
A friend coincidentally stopped by with his F150 today and I noticed that it was also only a brake light. Thank you both for the knowledge - I can't believe I never noticed before that it was a just a brake light. I guess as the driver, though, it's not something I'd really be aware of. Thanks again!
island eddie
Electrical Systems/Wiring
Nov 17, 2017 09:33 PM
Mizuez
Feb 23, 2016 08:12 AM
BettyBlue_96_PSD
Aug 2, 2015 10:08 AM
Genesis
Jan 30, 2014 06:40 PM
MemOrex
Jul 23, 2004 08:54 AM
