3rd brake light question.....
Old Nov 17, 2017 | 04:54 PM
island eddie's Avatar
island eddie
I have a 2011 F-250 that I purchased recently.
I noticed the 3rd light on the cab only had one light working, a cargo light, one of two.
I put in new bulbs, the other cargo lights then worked, but not the red brake light.
I noticed the socket appeared to have melted somewhat, as if it got hot at some point in time.
I purchased a new light bar online.
The change-out was straight forward, a mating plug, same mate.
I went and tried it out, the "red" light only comes on with the braking, is that the normal function?
I thought it was the same as the two main brake/running lights, yes....they light up when running, and brighten when braking, am I wrong on assuming this?
Thank you in advance!
Old Nov 17, 2017 | 08:42 PM
Franklin2's Avatar
Franklin2
Yes you are wrong. The rear lights have dual filament bulbs, the bright one hooks to the brake/turn, the dimmer filament hooks to the running light circuit.
The original 3rd brake light only has the brake function wired to it. It's actually a special dedicated wire going directly to the brake pedal switch, to avoid all the complication from the left and right turnsignals.
If the aftermarket light has the running light/brake light function, you could use it, but you would have run an extra wire from the running lights up into the b pillar and wire it in to your new light assembly.
Old Nov 17, 2017 | 09:33 PM
island eddie
Red face
Thank you.....
I was leaning that way, as the plug(s) female/male, were identical.
In hindsight it does seem to make more sense that having a light come on (the brake) when driving might get the follower attention a little better......all of a sudden a RED light comes on out of nowhere.
I just have to figger out how to wire in a siren, to get the full, "OH SHEET" effect
BIGPAPA1970
Dec 16, 2017 08:17 AM
broncobillyII86
Bronco II
Mar 10, 2006 07:01 PM
classyfish
Mar 7, 2006 08:52 AM
MemOrex
Sep 30, 2004 08:03 PM
