Steer column
Old Mar 10, 2023 | 08:22 AM
Drummer1120's Avatar
Drummer1120
1st Gear
Steer column
Hello. New here. Just picked up a 58 f100. I’m excited no rust holes, engine doesn’t smoke. Ran 65mph down the Freeway. 292V8. Question is..seems all the upgraded steer columns I find skip over these models. They stop at 56 then start in the 60s. Is there a steer column upgrade steer column somewhere for these. Original is in good shape virtually no play. Normal for old truck. would just like to put a tilt wheel and a hair smaller steer wheel. Manual steer.
Old Mar 10, 2023 | 09:28 AM
Byrd.Dog's Avatar
Byrd.Dog
On these trucks, the column and gearbox are basically one unit. You may be able to adapt a universal tilt column to bolt onto the factory steering gear, but it would require some fabrication. You could also go to a power steering conversion like CPP, but I have it on good authority that it requires modification of your clutch slave cylinder.
Gwilkrrs
Sep 12, 2022 12:09 PM
butchd88
Jan 10, 2022 09:50 PM
jays '56 f-100
May 2, 2019 11:12 PM
Cg willie Willie
Jan 18, 2017 09:14 PM
My9fam
Dec 16, 2012 10:42 AM
