Rke not working
Old Mar 8, 2023 | 01:24 PM
FelIxm13's Avatar
FelIxm13
Trailering
Rke not working
Hello everyone, I have a 97 f350 with the factory rke but po had lost original key fobs, so I bought some new ones that are the right ones, but when shortening the rke module the locks click but I go to press the button on the key fob and nothing happens, they have new batteries. The left rear door doesn't unlock or lock at all so I'm wondering if all 4 doors have to be working in order for the rke to work?
Old Mar 8, 2023 | 03:29 PM
knottyrope's Avatar
knottyrope
dont need all four to be working
my rear drivers side has not worked in years and other three will unlock or lock
Old Mar 8, 2023 | 03:45 PM
z31freakify's Avatar
z31freakify
Take them out clean them and regrease the locking motors usually they just get stuck with crud.
As for the RKE, maybe the Key FOB isn't program correctly? Or the wrong one for the application?
Old Mar 8, 2023 | 04:39 PM
JCart's Avatar
JCart
If any electric functions on the doors do not work especially the rear doors, check to ensure the wires in the accordion flex tubing in the door jam are not broken. Look very carefully at these wires, as they can become brittle from open/closing of door and break off (even inside the insulation). Easy fix, I use none insulated butt connectors with quality shrink tubing and don’t forget to use dialectic grease in connectors, just replace and add a little length to the wires.
cheers
j
Old Mar 8, 2023 | 07:51 PM
RubberDuck's Avatar
RubberDuck
May be wrong, but I think you are trying to say is "do all the locks have to cycle so the programming of the new fob will occur". When trying to program it...... I'm gonna say maybe so. The only reason I say that is because I ran into the same problem on my son's 4runner when trying to program his fob. The locks have to cycle 5 times, and since it's old, they slow, or don't cycle and the programming just doesn't work.
I would definately get that door to cycle and try again.
Old Mar 8, 2023 | 09:06 PM
FelIxm13's Avatar
FelIxm13
Trailering
Yes sir that is exactly what i meant thanks for the clarification and yes its weird cause all other doors cycle except for that one when trying to program
HarjD
2009 - 2014 F150
Aug 21, 2021 11:24 AM
Painted Horse
Jan 5, 2018 05:52 PM
palindromelol
Jun 30, 2016 06:29 AM
JNG6
Feb 22, 2015 07:41 PM
fifthwheel01
Jul 28, 2009 03:55 PM
