Rotomaster EBVP arm adjustment
Need some advice. Am changing the turbo pedestal. Bought an OEM replacement from Diesel O-Rings. The arm is adjustable same as the OEM unit but it came adjusted much closer inboard.
Do I just match the length to the OEM unit? The reason I ask is because the Rotomaster does not use an OEM actuator and it was marked with blue paint on the nut and arm.
Yes I know...many people delete the EBV.
Thunder Castle
07-29-2022 09:45 PM
Resendiz
07-20-2015 07:56 PM
mjshagnasty
32
08-08-2011 07:24 PM
