Headlight trouble
Old Feb 28, 2023 | 09:24 AM
crotallis's Avatar
crotallis
2nd Gear
Headlight trouble
I have a 93 f150 with the 5.0 l engine The flash to pass and low beam lights work The high beam lights do not work when you push it forward to engage them I have replaced the multi switch and have checked the wiring at the multi switch. This problem may be on this forum somewhere but I have failed to find it any help would be appreciated
Old Feb 28, 2023 | 10:12 AM
Mudsport96's Avatar
Mudsport96
Have you checked for voltage at the light socket? Also remove the headlight switch and check for burnt wired and connector there, it is a known problem for these trucks.
Old Feb 28, 2023 | 10:58 AM
crotallis's Avatar
crotallis
2nd Gear
Checking the headlight switch did not even cross my mind thank you
Old Feb 28, 2023 | 04:06 PM
tjc transport's Avatar
tjc transport
i ain't rite
also check the bulbs. i have had many times people come into the shop with no high beams, and it was simply two bad bulbs.
n0sliwkram
May 7, 2022 08:45 AM
1974xlt
16
Jan 13, 2021 06:49 PM
Tyler Drysdale
Apr 16, 2019 09:16 PM
cadougherty_67
Sep 1, 2017 06:24 PM
MichiganLarry
Jan 27, 2016 06:27 AM
