General question on small fuel pump operation?
Old Feb 28, 2023 | 09:12 AM
Squanto's Avatar
Squanto
If I have a gravity feed line from an aux diesel tank in the bed and I add a small pump. Would the fuel continue to gravity feed if the pump is not energized?
Old Feb 28, 2023 | 10:10 AM
rufushusky's Avatar
rufushusky
Just curious what would the small pump be used for? Pumping through a filter or just speeding up the process?
Old Feb 28, 2023 | 10:31 AM
JoeUser's Avatar
JoeUser
Depends upon the pump, I'd guess. If you're concerned about flow control, install a cutoff valve (such as this: https://www.ebay.com/itm/154758122093). After the pump, obviously.
Old Feb 28, 2023 | 10:41 AM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Maybe, but at the least flow would be slowed down quite a bit.
Old Mar 1, 2023 | 05:21 AM
Squanto's Avatar
Squanto
I wouldn't use that one which is made for water. But that's kind of the question. If I have a pump, would a solenoid be redundant?
Old Mar 1, 2023 | 06:15 AM
rufushusky's Avatar
rufushusky
IMHO, no. The pump would probably still let fuel pass through while a closed solenoid definitely won't.
Old Mar 1, 2023 | 07:03 AM
JoeUser's Avatar
JoeUser
I wasn't recommending that particular one, just using it as an example of a powered shut-off valve. Obviously, you'd need one that's rated for fuel.
Anyway, I'd recommend researching the pump manufacturer specs of whichever pump you're looking at, and ensure that their pump doesn't allow flow when not powered on. Most don't, in my experience, but confirm with the manufacturer specs...
Also, if you're concerned about flow from gravity, just mount the pump above the level of the tank from which you're using to pump fuel, simple solution. But, if you absolutely want to stop flow just use a powered cut-off valve.
Frank79
Jun 8, 2022 06:01 PM
aj92F250IDI
Sep 27, 2019 07:09 AM
Rudiak
6.4L Power Stroke Diesel
Apr 17, 2018 03:45 PM
mark460
Jan 14, 2015 02:18 PM
ford7.3l
Aug 17, 2010 03:22 PM
