Sponsored by: Auxito
Turn signal buzz
Old Feb 28, 2023 | 07:11 AM
60DRB's Avatar
60DRB
Turn signal buzz
Search showed no recent duplicate issue...
2001 XL 2WD with 4.2/V6 with auto XMSN. XL base trim with no tilt steering wheel. 136K miles.
Just lately, the turn signal stopped working when put to right turn position. Sometimes a buzzing noise happens with no dash flash indicator. Sometimes no buzz or flash indicator. Sometimes after a normal left turn signal/auto shut-off sequence the right turn works normal. Hazard flasher works.
You tube shows a few possible things; signal relay, multi-function switch/lever assembly, and loose wires to same.
I'm hoping somebody had this same issue and might save me some trouble shooting time before I dig into the dash & steering column covers.
Thanks for any help.
Old Mar 1, 2023 | 09:07 AM
manicmechanic007's Avatar
manicmechanic007
Replace the flasher, in your case, the electronic flasher relay
It is the blue one, pricy for a Ford one
Get three at the junkyard for ten bucks
Old Mar 2, 2023 | 05:19 AM
60DRB's Avatar
60DRB
Alright, I'll give that a whirl and update soon...
Thanks
Old Mar 5, 2023 | 11:04 AM
60DRB's Avatar
60DRB
Replaced flasher (blue) relay.
No change.
I'll replace the multi-function/turn lever assembly as I see no loose damaged wiring.
Officially throwing parts now...
Old Mar 5, 2023 | 02:01 PM
manicmechanic007
Bummer
The buzz is coming from the flasher relay right?
You unplug the flasher relay, and the buzz quits right?
The TS switch sometimes gets unplugged with repeated use of the column tilt
The grounds in the truck are okay?
I would check a few just for GPs Like the ones above the drivers feet, if any, and the ones behind the left kick panel;
Old Mar 5, 2023 | 07:56 PM
Jon Freeman's Avatar
Jon Freeman
..the turn signal stopped working when put to right turn position...Sometimes a buzzing noise happens with no dash flash indicator...Hazard flasher works.
Replace the relay for the flasher, test the signals before reassembling. Still not working replace MFS, retest.
Old Mar 6, 2023 | 11:37 PM
Airborne 82nd's Avatar
Airborne 82nd
Why is it blue what is different with it compared to a regular black relay? I think there must be a reason but never did know what?
Old Mar 7, 2023 | 12:33 AM
AntonyU21's Avatar
AntonyU21
4th Gear
Is the problem solved? I would also like to know how to solve this problem
Old Mar 11, 2023 | 12:06 PM
60DRB's Avatar
60DRB
OK, back at home again, and part was waiting on me.
Replaced the multi-function switch/arm and all is working perfectly again.
Answers to questions;
-The intermittent buzzing noise had quit by the time I got the panels off to start work. (somewhere inside the dash area was all I could tell)
-Why is the one relay blue? You'll have to ask Ford. Maybe it helped the worker during assembly at the factory. (and now I have an extra one) OR, because AA goes on a blue background, on a red square, Airborne!!
-As to wear and tear from tilt steering... this has a fixed steering column. Which made it a tiny bit more fiddly getting panels off, but not too bad.
Anyway, all better now!
crucialprospect
24
Mar 27, 2017 09:10 PM
hertz1438
Oct 16, 2009 06:42 PM
saleen065
Aug 26, 2008 09:35 PM
malinsk1
1997 - 2003 F150
Dec 24, 2005 10:12 AM
dwetopgun
Jun 23, 2003 08:13 PM
