Sponsored by: Auxito
Turn Signal
Old Dec 23, 2005 | 12:08 AM
malinsk1's Avatar
malinsk1
Turn Signal
I have a problem. My right front turn signal does not work. It does not work as a 4-way flasher or as turn signal, but it flashes when I unlock my door. I replaced the blub already. Any guess on the problem and how to fix it?
Thanks
Old Dec 23, 2005 | 09:23 AM
92merc's Avatar
92merc
Sounds like your multifunction switch in the column is bad. If you do a search on it, there's a how to here somewhere.
Old Dec 23, 2005 | 11:08 PM
Thudpucker's Avatar
Thudpucker
Yeah, mine too. Sometimes the Fronts will flash too quickly. Either one. But if you re-position the Turns signal lever several times, the light will begin to work correctly.
It's in the Multifunction switch in the steering column right at the steering wheel.
Old Dec 24, 2005 | 04:32 AM
mat-helm's Avatar
mat-helm
https://www.ford-trucks.com/forums/s...d.php?t=179397
Old Dec 24, 2005 | 08:34 AM
Thudpucker's Avatar
Thudpucker
OK for Matt-Helm, he wins the Research award for the Combination lever.
Some guys are better researcheres!
I copied all those instructions, and after the Hollidays we'll take a look at this little bugger.
Thanks.
Old Dec 24, 2005 | 10:12 AM
mat-helm's Avatar
mat-helm
No research, just a few brain cells that the beer hasn't gottin to yet.
thatsrealnice
16
Jul 31, 2020 06:00 PM
Nixoninc
Jul 31, 2010 04:28 PM
Duke78
Jan 17, 2010 04:58 AM
mdjwahl
1997 - 2003 F150
Jul 18, 2007 09:50 AM
