FINDING THE STEERING COLUMN HORN WIRE
Old Feb 27, 2023 | 04:15 PM
ForBruce's Avatar
ForBruce
ok so i bought a train horn and don't want to tap off the stock truck horns in the front grill . ( using 2 relays ---car horn relay & train relay would cause a delay)
so can anyone tell me how to find the steering column horn wire, which i believe grounds this wire when you press the horn on the wheel
P.s. --- 2020 f-250
update --been told bcm module (passenger right floor ) controls the horn relay in the engine compartment---so now i think i will have to tap into the coil of this relay to activate the train horn relay
Old Feb 27, 2023 | 05:30 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Yeah, wiring in the steering wheel and column are all multi-plex, do more than one task, so don't try and tap anything in there.
If I were you, I'd sure just run the train horn separately.
Old Feb 27, 2023 | 06:19 PM
Garbageman 134's Avatar
Garbageman 134
One relay actuating another will cause a minute amount of delay, like less than a second.
snaponprofile
Jul 24, 2011 01:44 AM
frigerator
May 24, 2009 06:16 PM
blk964xbronc
13
Jan 3, 2005 03:04 PM
JStan
Oct 17, 2003 06:23 PM
Tony G
Electrical Systems/Wiring
Apr 19, 2003 12:04 AM
