Horn button wire - Which one???
Old Apr 12, 2011 | 03:22 PM
snaponprofile's Avatar
snaponprofile
I need to tap into the wire for my horn button as I [plan on installing one soon. What wire is it under the dash that I need to tap into?
Old Apr 13, 2011 | 01:03 PM
snaponprofile
Bump? anyone know?
Old Apr 14, 2011 | 08:23 AM
rla2005's Avatar
rla2005
My EVTM for a 1993 F-series shows the ground path from the steering column to the horn relay coil is a Dark Blue wire. The 12V feed from the horn relay to the factory horns is Yellow/Light Green
Old Apr 14, 2011 | 08:38 AM
snaponprofile
Ok cool, thanks a bunch. I should just look at the harness going directly to the steering column I assume? I would tap into the 12V to wire in a horn right, no reason to mess with the ground, correct?
Old Apr 14, 2011 | 08:55 AM
rla2005's Avatar
rla2005
The 12V supply for the horn relay is located in the engine compartment fuse/relay box. The horn button in the steering column only supplies the return path to activate the relay.
This drawing might help you out:
Old Apr 14, 2011 | 09:07 AM
snaponprofile
Ya, I meant to the horn button. Can't I just tap into the horn button wire(Black wire on diagram) and put one end of the toggle in there so when the toggle is down only the stock horn will sound. But when the toggle is up, both will sound?
Old Apr 14, 2011 | 09:11 AM
rla2005's Avatar
rla2005
That should work.
Old Apr 14, 2011 | 09:42 AM
snaponprofile
Ok, thanks so much. I'll probably pull the fuse while doing it so I don't get shocked.
Old Apr 17, 2011 | 04:16 PM
Luvmyf250460's Avatar
Luvmyf250460
I am having a horn issue alsoon my 1990 F250. I tired using stock button in wheel cutting and bypassing harness wires. It was the wrong thing to try. I appreciate the wiring diagram. I am still unabule to locate horn relay. Any more throughts
Old Apr 17, 2011 | 10:38 PM
rla2005's Avatar
rla2005
Ford did change things around from one generation to the next. I do not have a diagram for a 1990. If I find something, I will post it.
Old Jul 24, 2011 | 01:44 AM
H00TY1's Avatar
H00TY1
horn relay
Originally Posted by Luv F250460
I am having a horn issue also on my 1990 F250. I tired using stock button in wheel cutting and bypassing harness wires. It was the wrong thing to try. I appreciate the wiring diagram. I am still unable to locate horn relay. Any more thoughts
horn relay should be under hood on passenger side. In between the battery and the solenoid..
F350moneypit
19
Feb 4, 2013 01:46 AM
1930 Dodge
22
Dec 19, 2012 09:44 AM
Freightrain
Jul 9, 2012 12:47 PM
av8r210
1983 - 2012 Ranger & B-Series
13
Apr 18, 2011 09:56 PM
PhilcoPGM
Dec 7, 2010 07:44 PM
