8 foot bed swap
Old Feb 25, 2023 | 09:02 AM
Rfarrands's Avatar
Rfarrands
2nd Gear
8 foot bed swap
Hi all, I've got an 09 150 with an 8' bed that is rusting away. Clean replacements by me are hard to find, and around $2500. That's expensive for a guy like me. F250 8' beds are more readily available and cheaper. So my obvious question is, can I swap a f250 bed onto my f150? Has anyone done this? Does it look OK? Does filler door match up easily? I'm not looking for perfection, just functionality.
Thanks for any help.
Old Feb 25, 2023 | 01:48 PM
acdii's Avatar
acdii
The best way to find out is to park next to a Superduty with the long bed. That way you can visually see the panel lines. What you also need to figure out is if the bed rails are in the same place and the bolt locations line up. For your truck you can use a bed up to a 2014 F-150, doesn't have to be an 09. Knowing Ford waits 2 MY between the 1/2 ton and medium trucks, you would look for a 2011-16 superduty, preferably gas, though the filler mount should be identical, you just have the extra holes for the DEF filler.
The cabs should be identical in dimensions which means the beds should align, but I am not certain the body lines between the two are the same. I do know the cab from my 2018 F-150 would drop right in place on my F-450 since they are the exact same size, from the firewall forward though, completely different. I don't know if the firewalls are identical though.
Anyway good luck finding anything in steel, there are plenty of 17+ beds, but the older steel ones are few and far between and not that great of shape either.
Old Feb 26, 2023 | 03:35 AM
tjc transport's Avatar
tjc transport
i ain't rite
no they are different.
Rfarrands
2009 - 2014 F150
Feb 25, 2023 06:53 PM
Seanmac1007
Feb 14, 2023 11:30 AM
jmtbiggin
Apr 8, 2022 06:20 AM
sergeantsausage
Apr 8, 2022 06:14 AM
StrokinHer01
May 29, 2019 08:53 PM
