Coolant temp off??
Old Feb 24, 2023 | 07:49 PM
that 6.$'s Avatar
that 6.$
5th Gear
Coolant temp off??
So I have a almost bone stock truck except straight pipe and a tune but it’s just a mild 40 horse for mpg but the tune shut down the egr so it doesn’t use it now I haven’t did the delete yet but for some reason I always Monitor my oil and coolant delta but recently it’s been off and I believe a sensor went bad because my tuner says my oil will be like 189 but coolant with be at 160 flat not a decimal or anytimg and will stay that way but in park it goes right back to normal at a 8 degree delta and it’s werid bc my truck normally is runs cool my oil temp never gets over 190 and it rarely reaches that so I think something has gone bad
Old Feb 24, 2023 | 07:57 PM
jmaskew's Avatar
jmaskew
To test the sensor, you can swap them (they are the same). Just clean them first of course. lol
Old Feb 24, 2023 | 08:00 PM
that 6.$'s Avatar
that 6.$
5th Gear
yea I’ll try it but it’s just weird all of a sudden my engine seems healthy my oil temp never gets to high even on long drives but this last week it’s been off by 30 degrees and it’s only resting on like whole numbers
Old Feb 24, 2023 | 08:01 PM
that 6.$'s Avatar
that 6.$
5th Gear
And I just changed my oil but I’m thinking I’ll do a coolant flush but it just seems weird
Old Feb 24, 2023 | 08:19 PM
jmaskew's Avatar
jmaskew
I Have replaced the oil and coolant temp sensors a few times because of similar readings. The good thing is they aren't too expensive.
Old Feb 24, 2023 | 08:26 PM
that 6.$'s Avatar
that 6.$
5th Gear
Yea I’m just worried i unplugged my egr idk if that could be causing it or what but it just started a few days ago
Old Feb 24, 2023 | 09:52 PM
Motohead911's Avatar
Motohead911
It could also be a pigtail issue.
Old Feb 24, 2023 | 11:59 PM
IHateCommieCars's Avatar
IHateCommieCars
After sitting overnight are both sensors reading ambient temps correctly at KOEO?
Old Feb 25, 2023 | 06:53 PM
that 6.$'s Avatar
that 6.$
5th Gear
oh no lol I figured it out I unplugged me egr bc the sct x4 already closes the valve but I plugged back into and it’s reading perfectly
Old Feb 25, 2023 | 07:00 PM
IHateCommieCars
great news, but SYK, I doubt your SCT can do anything to the EGR valve if it's not plugged in.
Old Mar 2, 2023 | 12:50 AM
BryanStein's Avatar
BryanStein
yep. I a just about to post about that. Me coolant temps would do that after some rodents chewed through some egr wiring. Coolant temps would jump up and down 20 degrees or so while cruising down the highway.
juanrodriguez
May 30, 2015 01:44 PM
Ken_C
Feb 11, 2013 08:01 AM
carmk
Apr 18, 2012 08:27 AM
embry1123
Mar 15, 2011 05:14 PM
Whitey Ford
17
Jul 17, 2010 11:14 PM
