Clutch inspection
Old Feb 24, 2023 | 10:56 AM
kd5zll's Avatar
kd5zll
Clutch inspection
Can i, ate least partially, inspect my clutch to determine condition, without removing the tranny and clutch from the truck? I know plenty of you have r&r these items, so even though i never have, im confident, that if the need is there, ill get it done. What i know at the moment, is my zf6 is rebuilt. Dont know about the clutch, though at 270k im assuming its not original. Truck would drop out of overdrive when i got it.... randomly. Found a loose bolt when i did injectors amd turbo last year. Tightened it, and almost removed that problem, but now, ive been developing an issue shifting into L, and sometimes R.... i have to put the clutch pedal against the floor when this happens, to get it in gear. Othertimes, i can shift normally. Without actually going to the floor. All that to say, i know im developing wear.... i know im going to have to get in there, eventually. Just trying to sort out how much might be involved, ahead of time.
Old Feb 24, 2023 | 11:06 AM
knottyrope's Avatar
knottyrope
change clutch MC fluid (suck it out with a baster) and remove and push in slave 10 times to bleed
if that dont fix it then its possible your clutch is worn
You can take off inspection plate and measure disc thickness from below
dont take long to pull trans back but get a trans scissor jack from harbor freight if you dont own one
Old Feb 24, 2023 | 11:11 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
CaptainFacePunch
22
Mar 22, 2015 10:21 PM
Pwnm30rdi3
Jun 6, 2012 06:05 AM
3TreeGuy
Jun 2, 2009 07:44 PM
lucky no. 7
Jul 21, 2008 10:52 PM
cmoore101
May 13, 2004 10:33 AM
