Hi, I have a 1992 F150 4x4 with the 5.8V8 and the E40D transmission. The transmission was just rebuilt and I installed a trans cooler. The truck has 35 in tires and 4.10 gears. I am still having problems were if I drive it through decent wind or up hills, the transmission will get hot and the torque converter wont lock up. It will also slip out of gear when it gets hot. I have not installed a transmission temp gauge so I'm not sure of the operating temp when this occurs. Thanks.
The transmission must be slipping to be having trouble in the wind or climbing hills. Low line pressure? Unless you were the e4od rebuilder you need to take the truck back to whoever did the job.
There was a post about an e4od slipping in second or third gear(?) and Mark K said the transmission was probably toast if he drove it like that for any distance. Good luck.
As with any problem, the first step is to prove you have a problem.
Transmission temp gauges are cheap and easy to install. It doesn't need to be a permanent installation.
If I remember correct, mark kovalsky recommends factory rad cooler, then auxiliary cooler. I’m about to try a Tru-Cool aux cooler with a 180* thermal bypass.
You need a temp guage. When it over heats, it will go into limp mode.
Depending on who you talk to, that's the correct way of doing it.
There are two schools of thought on how to do this.
One way is to go from the trans to the radiator, then to the aux cooler, then back to the trans. The other way is wrong.
The radiator cooler is FAR more effective than the aux cooler. It will take A LOT more heat out of the ATF. Then the aux cooler lowers the temperature a bit more. If you route it the other way you will slightly increase the efficiency of the small (aux) cooler while diminishing the efficiency of the main (radiator) cooler. You will not cool the trans as much this way.
