I'm using the Vgate VLinker FS USB OBDii connector. The SCMG and SCMH modules are new from Ford and have never been in a vehicle before. I did provide the VIN of an F150 that had multi-contour seats when I ordered the adjuster with modules for my upgrade. Do I use the wrench section of Forscan to somehow do a PMI? Problem is the modules are never listed and I'm not sure how to get that process going. Don't want to go to Ford for this. I did activate the "enhanced multi-contour seats" using Forscan and I now have the driver and passenger seats shown on the center display. Both are grayed out and nothing happens when I try to select driver or passenger.
You are using a recommended adapter as listed on the FORScan website. I am using the OBDLink EX. Other than checking the connections again I am at a loss here. I would start with the large connectors under the pass and driver seat and make sure they are fully seated. My pass was not fully seated and FORScan didn’t see it but it did on the drivers side. I didn’t have to do any PMI procedures on the modules. I’m hoping someone can assist you more than I can.
Thanks to ZooDad, finally figured out the programming.
My initial changes were enabling the multi contour seats and enhanced multi contour seats in Forscan using the plain English BCM programming.
Then programmed the asbuilt for SCMH and SCMG using the following:
713-03-01 xxxx xxxx 6Axx
712-03-01 xxxx xxxx 6Axx
Now I have fully functioned multi contour seats in my 2022 Lariat.
You are a lifesaver. I have a 2021 Navigator with the perfect position seats and I was messing around with Forscan and saw an option for enhanced multi contour seats. I've been going crazy trying to enable the extra massage options and I couldn't figure it out. Your setting finally allowed me to have all 5 massage options that were locked away from the factory. Thank you!
