Common sense would dictate that the front seats in my '03 SD should be the same left to right. I mean the seat cushion/foam/leather part. Right?
Does anyone know if it is fairly simple to swap them left to right? I have dual power, heated seats, so I would think there shouldn't be a problem. No?
My truck has 170k on it, almost ALL of that with no one in the passenger seat. Well I am pretty sure all 170k had someone in the driver seat so you can imagine the difference in the seats. Just thought I could try to swap them.
I looked a lot closer and found that the seat bottoms look to be different enough to not be able to swap sides. The reason I wanted to swap is the seat bottoms. The back on the driver side is ok, it is the bottom that I thought I could switch even up. Not so.
It is not bad enough to need replaced. I just thought it would be cool to start wearing out the other side now.
