Ignition re-wire
Old Feb 23, 2023 | 05:58 PM
My4Fordtrucks's Avatar
My4Fordtrucks
I think you’re putting the cart before the horse. Cycle the ignition lock cylinder. Are the rack and and actuator moving? Did manually manipulating the ignition switch make the truck start?
Old Feb 24, 2023 | 08:37 AM
Franklin2's Avatar
Franklin2
Originally Posted by chucketn
No tilt...
Are you familiar with how the tilt works on these trucks? You push the turnsignal lever toward the dash to activate the tilt. Make sure to support the wheel when you do it. You can usually look at the slot in the side of the column and if it looks like a fat "T" you will have tilt.
The column actuator certainly may not be the problem. Just something easy to check. You can try the other suggestions also.
Gdsmith07
Oct 25, 2021 05:14 PM
The Fool On Th Hill
Apr 11, 2012 12:47 PM
Trinity Precision
Jan 8, 2012 01:59 PM
stretch5881
Oct 17, 2006 03:02 AM
jake_i_am
1978 - 1996 Big Bronco
Mar 21, 2003 07:53 PM
