FE crank keyways
Old Feb 22, 2023 | 02:49 PM
belate1's Avatar
belate1
3rd Gear
Question FE crank keyways
I'm lost. We had to replace our 390 with a salvaged 360. The 360 crank has a keyway that doesn't fit the 390 crank spacer. The 390 spacer has a slightly narrower keyway cut into it and I can't locate a spacer with a keyway that will mate w/ the 360 crank. Any suggestions or a lead on a spacer that will fit? Thanks in advance. This looks like a very good forum and I'm anxious to go thru it soon.
Old Feb 22, 2023 | 03:24 PM
beartracks's Avatar
beartracks
I don't do FE but it could be you need the spacer/balancer for the size engine.
Old Feb 22, 2023 | 03:32 PM
440 sixpack's Avatar
440 sixpack
Are you sure it doesn't just have a burr on it or something ? I thought all FE's took the same spacer. maybe the FT's are different.
Old Feb 22, 2023 | 03:37 PM
85e150's Avatar
85e150
OP says 360/390. If he got an FT by mistake he would have crank diameter issues.
Old Feb 22, 2023 | 03:54 PM
440 sixpack
Probably. but a 352-428 FE are supposed to take the same spacer.
I'd guess something got hammerd on and swelled .
Old Feb 23, 2023 | 08:04 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
In many years of putting together and swapping parts around in FE engines, I have yet to run into a crankshaft key/spacer issue. They have all been the same.
elkarcher1716
Apr 27, 2016 08:47 PM
9d4
Aug 21, 2009 09:28 PM
tylstruck
Dec 18, 2007 08:38 AM
Andysutt
15
May 19, 2003 05:22 PM
earthworms
Mar 28, 2001 11:19 AM
