Crank no start randomly. FIXED!
Old Feb 20, 2023 | 11:25 AM
z31freakify's Avatar
z31freakify
2014, F150, 2wd, Auto, 196k
Have a truck that driver says it will randomly crank and the starter stays engaged but will not start, he said he let the truck sit for a couple of minutes and it started, I tried to duplicate the problem to no available.
Installed my scanner and the only code that is triggered is a U0422 which is an "invalid data received from body control module".
Does this code have anything to do with the problem?
Old Feb 21, 2023 | 07:32 AM
2jhanna's Avatar
2jhanna
Has the Fuse 27 relocation been done. Pull F27 from the under hood fuse box and inspect the fuse and look down in the socket and inspect the contacts and wires. See if any burn marks or discoloration.
Old Feb 21, 2023 | 11:34 AM
RLXXI's Avatar
RLXXI
That code can mean a few things and could be related to the problem however you'll need IDS to figure out what's causing it. It's also a code that can be displayed if the trucks pcm has been flashed with a custom tune. Definitely check fuse 27 as mentioned.
Old Feb 21, 2023 | 01:08 PM
z31freakify
Thanks for the replies I'll check fuse #27 and report back, now I have something to start my diagnosis.
Old Mar 18, 2023 | 05:16 PM
z31freakify
Fixed!
Exactly what you guys said, melted socket on fuse #27.
Cut the wires going there and relocated it to the side of the fuse box with an aftermarket fuse holder.
Thanks again for the help.
Old Mar 18, 2023 | 06:21 PM
2jhanna's Avatar
2jhanna
freak, good move taking the initiative to repair without the TSB kit. I've often thought that a simple aftermarket fuse holder and length of wire would do the job just as good.
Visurveyor
Nov 9, 2021 06:50 PM
F0rdc0wb0y
Feb 9, 2021 09:13 PM
Chevy1994
6.4L Power Stroke Diesel
Jan 12, 2018 08:02 AM
fordf350man
22
Nov 23, 2016 03:46 PM
Jmatthews
Sep 9, 2008 06:37 PM
