6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
6.4L no crank u0101 Code
Old Jan 11, 2018 | 09:07 AM
Chevy1994's Avatar
Chevy1994
Have a truck here that will not crank DPF had went into regeneration then customer stop put in park and vehicle quit. customer says truck told him to stop vehicle. Need some help diaging this one.
Old Jan 11, 2018 | 12:14 PM
73F700's Avatar
73F700
Check out this thread; https://www.ford-trucks.com/forums/1...0101-code.html
Post 3 gives a step by step.
It would appear that the issue is not related to the regen, but a simple computer communication issue. It seems normal for a no crank with this code.
Old Jan 11, 2018 | 01:41 PM
Chevy1994's Avatar
Chevy1994
i Jumped the Starter Relay and got the truck started. Now The Truck starts fine.
Old Jan 11, 2018 | 01:54 PM
73F700's Avatar
73F700
Interesting. It is possible that you have a bad ground or connector that caused the issue. It could reappear unless it is found and corrected. Could've been a brain fart in the computer too.
Probably easiest to leave it and see - just don't be too surprised if it returns.
Old Jan 12, 2018 | 07:57 AM
sxrfun's Avatar
sxrfun
I assume you scanned for codes? A faulty exhaust sensor will cause the pull over now message as well as a no crank........
Old Jan 12, 2018 | 08:02 AM
sxrfun's Avatar
sxrfun
ha ooopsy...i see headline says it has a code......disregard my scanned for codes question then lol
B-2
1997 - 2003 F150
21
Aug 15, 2018 05:21 PM
Jmatthews
Sep 9, 2008 06:37 PM
pur pony
2004 - 2008 F150
Oct 18, 2005 08:19 PM
boulderbronco
1978 - 1996 Big Bronco
Apr 20, 2004 07:32 PM
