Back up sensor head scratcher
Old Feb 19, 2023 | 03:23 PM
Watcher58's Avatar
Watcher58
After 4 xs, Ive seen a lot of wierd things and now I have logged another one. The backup sensor system failed. I replaced the speaker and all 4 sensors. It still did not work.I ordered 4 more sensors. My scan tool said the outside right and outside inner were bad. I changed both. Both center sensors now work but the two outside do not work. I re[;aced the others. Still the only ones that produce a speaker signal are the two center ones. I took a conductance wand and all 4 sensors are working and at the same intensity. So the inner 2 create an audible signal through the speaker but the outer 2 do not. Anyone have any ideas?
Old Feb 19, 2023 | 06:28 PM
01__Excursion's Avatar
01__Excursion
Check this post in my thread, I recently installed the factory Park Assist system as I never was equipped with it. One of the PAM modules had corroded terminals at it's plug, plus I had a bad speaker. The poor plug connections threw several codes. The way the PAM module is tucked away, I'm not sure how it got wet, the A/C hoses are there, but appear to be far enough away to cause any issues.
https://www.ford-trucks.com/forums/1...l#post20381654
Old Feb 21, 2023 | 06:18 AM
Watcher58's Avatar
Watcher58
where do you find the PAM? I replaced all the sensors but then find that my fuel gage flat lines--then comes back overnight. Seems like there would be a common fault with a ground but I know not where to look.
THE ABS light came on for a while and it went away. All of this at the same time. It's a California car so not rust. GREMLINS!! Any other thoughts?.
Old Feb 21, 2023 | 12:36 PM
01__Excursion
Maybe get Forscan on there to see if any codes. My PAM threw codes that didn't trigger the CEL. I have a 2000 spare parts X, and I frequent the salvage yards and grab. So I have a couple modules.
2019f350
Jan 13, 2019 08:18 AM
toby tough
1997 - 2003 F150
Apr 22, 2015 12:57 PM
gccch
2004 - 2008 F150
Aug 25, 2014 12:50 PM
The2003Excursion
Apr 1, 2014 08:51 PM
optic462
1983 - 2012 Ranger & B-Series
Jul 31, 2007 02:14 PM
